Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2012-06-28, 00:33   #1
safcomaverick72
Member
safcomaverick72's Avatar
Vehicle(s): ford maverick 72
Images: 45
Question help! electrical fault!
hello I have a maverick 72 and turn signals not working, everything is connected properly. that could be wrong?
safcomaverick72 is offline   Reply With Quote
Sponsored Links
Old 2012-06-28, 01:23   #2
captainmack
Quad Door
captainmack's Avatar
Vehicle(s): 1972 4 Door Comet, 200, C4 1970 Dodge Coronet 1975 Econoline 250
Images: 26
I have a 72 .. I had to replace the Turn signal switch in the wheel... got my part on ebay. make sure the clicker pot is ok first... a very inexpensive item from local store. Warner 552..(I think) there is one for the emergency blinkers and one for the turn signals. Do the emergency blinkers work? then its the pot. I doubt BOTH are bad. If not then you have to pull the wheel (wheel puller) and install a new turn sig sw. harness.. The hard part is getting the wheel off.
__________________
Mercury; a step up from Ford but not quite a Lincoln
captainmack is offline   Reply With Quote
Old 2012-06-28, 02:11   #3
safcomaverick72
Member
Images: 45
Quote:
Originally Posted by captainmack View Post
I have a 72 .. I had to replace the Turn signal switch in the wheel... got my part on ebay. make sure the clicker pot is ok first... a very inexpensive item from local store. Warner 509..(I think) there is one for the emergency blinkers and one for the turn signals. Do the emergency blinkers work? then its the pot. I doubt BOTH are bad. If not then you have to pull the wheel (wheel puller) and install a new turn sig sw. harness.. The hard part is getting the wheel off.
the sw of directional and non-emergency work. multimeter with a continuity gave me all the wires to the harness. Therefore I think that still works the emergency button and turn signals, I think it could be a flasher, but I put a new and yet not, maybe I'm missing some gnd?
I am leading with this diagram.
http://1bad6t.com/Maverick/repair/pd...rickwiring.pdf
even remove the protective isolation and disconnect all harnesses to make sure everything was in order but still could not find the fault.
Reply
Interested in this thread?
Bookmarks
Tags
electrical, fault, sistem, turn signal
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
