| Sponsored Links |
#2 |
Senior Member
Welcome to the forum tbucket.
__________________
Ephesians 2: 8,9 |
#4 |
Bob Hatcher
from a fellow 70 owner in Northeast Pennsylvania
__________________
Every step of my project has been temporarily impossible My Insane 1969.5 Street Project Thread |
#6 |
Hangtown Hot Rods-NorCal
Welcome from Nor Cal!
__________________
306/Summit hypereutectic pistons/10:1 compression/Lunati bracket master II cam & lifters-284* duration .488 lift advanced 4*/CompCams dbl roller timing set/Edelbrock valve springs/Stock rockers/Stock heads/Summit stage II dual plane intake/Holley 770 "Street Avenger"/Pertronix elec. ignition/Melling hi-vol. oil pump/MSD coil/Hedman headers/Magna Flow/C4 w/ big Billet servo & blue bands/Hughes "Street Master" 2500 stall conv./TransGo stage II shift kit/B&M Megashifter/Ford 9"/4 Wheel Disc |
#7 | |
Bob Hatcher
Quote:
If so, you need to pull up your trunk mat and you will find that the tank is part of your trunk floor. There are a lot of small bolts around the entire tank lip bolting it to the bottom of the tank well. Get the gas out of the tank first if you can, remove all of the bolts, sending unit wires, gas hose and your filler neck and the tank should lift up and out through your open trunk lid. 1969.5 & 1970 Maverick are the only ones built this way. 1971 and up went to the tank being strapped up under the trunk floor
__________________
#8 |
Senior Member
to the site...
#9 |
Roger Saffle
Vehicle(s): 1970 Grabber CloneiTrader: 6 (100%)
Welcome from a fellow 70s owner. The gas tank was, so far, the hardest thing for me to find. In fact I never did. No one makes an after market tank for it. Like stated above, it is part of the trunk floor. I ended up taking mine and having it redone. I think it cost me $225
Pics here.... http://smegnl.medina.oh.us/index.php...rick&Itemid=54 |
#10 | |
Frank Cooper
Quote:
nice job on the tank... the sock is to keep trash out of the fuel pump...
Interested in this thread? Receive email updates and post your own response by registering today, it's free! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
