Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2012-08-09, 20:13   #1
rigrunner
Member
Vehicle(s): 1974 comet 250 inline 6 c4 auto
turn signal issues. need help bad please
my dad just bought a 74 comet. all the lights work but the turn signals. the hazards flash but the dash indicators do not blink with them. the signals do not work at all. i checked the flasher for the blinkers and it is good. all fuses are good. i ran a jumper to the single blue wire on the flasher and when the left or right blinker is selected it will light up outside the car but wont blink so i think the t/s switch is good. and also the dash indicator lights do not light up with the blinker. im stumped. wondering what could be the cause of this. the grounds all look good too. any chance the circuit board is bad in the dash and if so can i bypass this? sorry for the long post and thanks in advance.
rigrunner is offline   Reply With Quote
Sponsored Links
Old 2012-08-09, 20:45   #2
maverick@heart
Member
maverick@heart's Avatar
Vehicle(s): 1975 American Maverick, 1976 Mexican Maverick, 1973 Maverick
I just recently had that exact issue. The flasher seemed to be good. Ichanged both flashers and the issue got corrected. How or why? Who knows!!!!
__________________
GOD gave us all a limit. That limit is the Sky.
Dios nos dio un limite. Ese limite es el Cielo.
maverick@heart is offline   Reply With Quote
Old 2012-08-09, 20:48   #3
Craig Selvey
Indiana State Rep - MCCI
Craig Selvey's Avatar
Vehicle(s): 1972 Maverick Grabber - Color: Orange Also, 1976 Ford Maverick 4-door, 1977 Mercury Comet 2-door. Daily driver: 2005 Ford Focus SE Station Wagon
Images: 431
Based on the info you gave us, I would guess turn signal switch. But I would rule out everything else first. Start with the bulbs.
__________________
Craig's Maverick Corral: http://www.maverickcorral.com
To email me DIRECTLY, do NOT click on my name to the left and choose an option, instead, email me DIRECTLY at:
Craig Selvey is offline   Reply With Quote
Old 2012-08-09, 20:55   #4
x72COMETx
Member
x72COMETx's Avatar
Vehicle(s): 1972 mercury comet
Images: 10
i think im going to keep an eye on this post because i have that exact same issue but i checked everything i even bought a turn signal switch for $130 and that still wasnt the problem.
x72COMETx is offline   Reply With Quote
Old 2012-08-10, 18:08   #5
pegleg1858
Member
Vehicle(s): 69 1/2 maverick
Images: 5
Also check the grounds.
pegleg1858 is offline   Reply With Quote
Old 2012-08-10, 21:20   #6
rigrunner
Member
ok. so far ive checked all the grounds. all the bulbs light up with the hazards so i say there ok. pulled the wheel and was hoping to be able to test the turn signal switch with no luck. is there any way to check the switch? also wondering if the circuit board on the back of the intrument cluster is bad would it cause the blinkers not to work? wiring diagram looks like it connects there. im stumped. hate to buy a new switch if this ones good. thanks.
Old 2012-08-10, 21:47   #7
rigrunner
Member
does anyone know if a older maverick t/s switch will work in a 74? my cousin has one he wrecked years ago sittin and i may can get the switsh there if it works. im gonna say its early 70s 70-72 maybe
Old 2012-08-11, 08:49   #8
Craig Selvey
Images: 431
Quote:
It may work. Just depends on how it plugs into the main wiring harness. If the plugs are the same, I would say it should work.
__________________
Old 2012-08-11, 12:09   #9
rigrunner
Member
thanks. ill get back at it next weekend. took it to get front end aligned and gotta have new tie rods so itll be in the shop next week.
Old 2012-08-25, 16:48   #10
rigrunner
Member
got the car back today. went over all the wiring grounds and connections again and still no turn signals. im stumpeed...
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
