Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2012-10-19, 11:54   #1
facelessnumber
Drew Pittman
facelessnumber's Avatar
Vehicle(s): '71 Grabber
Images: 49
I keep killing u-joints...
Ever since the 351w swap, my car's been hell on u-joints. I keep busting the bearing caps. Stock rearend, C4, stock driveshaft, engine mounts are the same as I had on my 302. It's smooth as can be, there are no driveline vibrations... I am using 1" lowering blocks but they've been on the car for years. I don't think there's anything wrong with the pinion angle.
I drive the car all the time, and yes I have a lead foot. Is this just part of the deal when you put a lot of torque to a stock driveline, or is something likely to be wrong? I'll just keep putting u-joints in every few months if I have to, but that doesn't seem right. I don't want to ignore a problem if I have one, but I also don't want to be chasing down some non-existent issue either.
__________________
351w .040" over, GT40 heads, Comp XE268H (268/280, .510/.512), flat top pistons, MSD 6a, headers, double pumper, trans kit, stall, shifter, BFV suspension,
3.25 TrueTrac, 4 disc power brakes, power steering, air conditioned, clean, and driven daily.
"I am a fountain of bad ideas. Never attempt to do anything I suggest, ever."
facelessnumber is offline   Reply With Quote
Sponsored Links
Old 2012-10-19, 11:58   #2
mercgt73
Senior Member
mercgt73's Avatar
Vehicle(s): 1973 Comet GT, 1974 Mustang II
Images: 6
Are you breaking the diff yoke end or the trans yoke end?
Could wheel hop be snapping your u-joints?
When you installed the last new ones, were they free to rotate and not binding?
__________________
-- Rusty
mercgt73 is offline   Reply With Quote
Old 2012-10-19, 12:07   #3
facelessnumber
Drew Pittman
Images: 49
It's been the rear u-joint so far. I'm hearing that telltale clank again and I haven't checked, but I'm pretty sure it's the rear one going out on me again. When I installed it last, it was moving smoothly and I greased it up good.
I'm not having any wheel hop.
__________________
Old 2012-10-19, 12:28   #4
Mavaholic
Growing older but not up!
Mavaholic's Avatar
Vehicle(s): Original 72 Sprint Owner, 71 Comet GT, 69.5 Mav convertible project, 57 Ranchwagon
Images: 20
Pull the driveshaft and have it checked for trueness and balance.
__________________
My Comet GT Build
"Todays racing technology has diminished the role of the driver way too much. Back in the days of 4 speeds, the driver had a lot more to do with the outcome of the race, and I can't imagine anything being more fun than that." Ronnie Sox
Mavaholic is offline   Reply With Quote
Old 2012-10-19, 12:29   #5
mercgt73
Senior Member
mercgt73's Avatar
Images: 6
And as far as you can tell, the pinion yoke, u-bolts and driveshaft ends all look OK? How do you replace your u-joints? Do you use a press or a one of these: http://www.grainger.com/Grainger/WES...121019172915:s
__________________
-- Rusty
Old 2012-10-19, 12:32   #6
Joe Dirt
six poppin'
Joe Dirt's Avatar
Vehicle(s): 1973 4 door
Images: 89
Overtightning the straps distorts the bearing caps and causes this type failure
__________________
1973 Maverick- 4 door Gapp & Roush tijuana Taxi "clone"
1957 Chevy 2 door post Turbo lsx GASSER project
Please visit my website!
https://www.facebook.com/JoeDirtFabrication
Joe Dirt is offline   Reply With Quote
Old 2012-10-19, 12:41   #7
simple man
Senior Member
simple man's Avatar
Vehicle(s): 74 Maverick - 82 Ford Ranger,one of the first ones made!
Are they ones with the large needle bearings or the small needle bearings? The ones with large needle bearings are garbage! Try to get some that have the small needles and you should be good to go!
simple man is offline   Reply With Quote
Old 2012-10-19, 12:47   #8
junrai
Senior Member
Vehicle(s): 1972 mercury comet 1972 comet gt
Images: 41
when you put in your u jioints are you making sure theyre in between the little tabs? Ive done that a few times changing mine. in a rush or cant see or just plain dont to be fixing on anything and not paying attention that will give you trouble. but maybe your rear end has just a little play in it where it slams the ujoint every time you step on the car a little
junrai is offline   Reply With Quote
Old 2012-10-19, 12:48   #9
injectedmav
Member
injectedmav's Avatar
Vehicle(s): 1972 Maverick 2dr 5.0l EFI, 2003 Expedition(wife's), 1991 Toyota p/u
Images: 28
I had the same issue and I thought it was pinion angle so I went to hell and back trying to get it just right. I finally got frustrated enough to take the driveshaft to a local driveshaft repair shop. He spun it up on the machine and it was shaped more like a banana than a precision driveline component. He was able to straighten it and rebalance it. So far so good. I had this driveshaft shortened by a different facility and I had returned there when I had the first rear joint failure and they told me it was fine.
The cap u-bolt torque and using the correct rear joint is critical. The u-bolt caps are thicker and some parts databases show both joints to be the same. I assure you, they are different, just in case you didn't already know.
__________________
"Do or do not, there is no try."
Yoda
injectedmav is offline   Reply With Quote
Old 2012-10-19, 13:06   #10
cyclonewill
Member
cyclonewill's Avatar
Vehicle(s): 69.5 Maverick - (2)72 Maverick- 64 comet cyclone- 69 mustang 70 cougar -69 Ranchero - 69 Cobra-
Quote:
Took me a few times to figgure that one out.
__________________
----Will
cyclonewill is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
