302 rebuild
Discussion in 'General Maverick/Comet' started by ErthwermJym, Oct 21, 2012.
  1. ErthwermJym
    ErthwermJym Member
    eugene, oregon
    1977 2 door base maverick
    I've never rebuilt an engine before and my knowledge isn't very expansive. I'm looking at rebuilding a302. What are the best books for my purpose? Thanks
  2. rthomas771
    How to Rebuild Small-Block Ford Engines by Tom Monroe
  3. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I have one that's already rebuilt. Email me if you are interested.
  4. Acornridgeman
    Wisconsin
    I'll add -
    Ford V8's On a Budget by George Reid
    Ford Performance by Pat Ganahl
  5. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    George Reid also did a how to build a small block ford book it also has a performance how to section
  6. bmcdaniel
    Or you can subscribe to Woody's video series. I think he has about 90 videos on the subject. If you aren't familiar with him, he's an engine builder that specializes on small block Fords.
    http://sbfbuilding.com/
  7. 71gold
    :Welcome: :Handshake
    you will also need some...special tools...:tiphat:
  8. ErthwermJym
    ErthwermJym Member
    eugene, oregon
    Thanks everyone, my plans for rebuilding a 302 has been postponed for a later date; I'm a student and have a finite amount of money. I'm looking now at a 250 rebuild. I'd like to get as much power out of a 250 as possible on a budget. Any info is greatly appreciated.
    Also does anyone know where I can get a pumpkin? Mine is knocking like crazy
  9. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    Its actually cheaper to build a 302 for power if you're worried about budget. There is a much smaller market for the inline 6 stuff so performance parts cost substantially more, whereas 302 performance parts are everywhere and cheap.
  10. ErthwermJym
    ErthwermJym Member
    eugene, oregon
    What I have read,i noticed that the 302, 289, 250, and the 200 use the same trans; C4. 302s are larger, of course, does there need to be anything special done to the trans for the 302?
  11. junrai
    junrai Member
    rancho cordova ca
    you dont have to do anything to the transmission if you plan to keep the 302 stock you will however need a v8 flywheel. the sky is pretty much the limit with the horsepower and transmissions on a 302 it just depends on how much money youre willing to spend. look at the new mustang with the 5.0 theres one I saw in a magazine with over 1000 horse power:hide:
  12. 71gold
    I think the 200 is different...:yup:
  13. Krazy Comet
    Dismal Swamp
    The trans used with small displacement engines almost always have less clutches, won't usually last under a high HP/torque application... In this case the 250 trans may be OK for a fairly stock 302, but I'd not trust one from a 200(plus the bellhousing won't interchange anyway)...
    EDIT
    Of course by now there are few original C4 left in service, and most rebuilders will upgrade the light duty versions to the higher rated specs, just so they don't have to stock two different versions...
  14. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Is your 250 dead? I say drive it til it dies and wait for someone hard up with a 302 laying around. Or if you want a project, you could try and find a 302 block already machined and built. Then just do the rest of it yourself - heads, pushrods, intake, carb, waterpump, alt, ect..
    Correct me if I'm wrong - I thought they put the same trans in the 302 and 250 Mav's, but the 200 and bellow had a different C4. There is a TON of info about this on the forum
