shelby drop results?
Discussion in 'Technical' started by Bryant, Nov 21, 2012.
  1. Bryant
    for the people who have done the shelby drop on their cars, was their any noticeable results?
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Yes,handling is noticeably improved. It's definitely worth the effort IMHO.
  3. Mavman72
    You will notice better turn in response and less push through corners with the arning drop. Just pay close attention to your upper ball joints. They are being worked harder with the mod, due to the increased camber angle...
  4. 74merc
    74merc computer nerd
    1974 Comet
    Would anyone mind posting a link?
    I've searched and found conflicting information.
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Total Control makes a template for drilling the hole, a little expensive but better than screwing it up:
    http://www.totalcontrolproducts.com/drill_jig.html
    Micah
  6. Maverocket
    Northwest
  7. Streamliner
    Streamliner Member
    Yes, definitely looks better
  8. Bryant
    thank you for the responses. i will be doing this.
  9. groberts101
    groberts101 Member
    Minneapolis, MN
    when I do that mod on my cars.. I always go for broke with the largest possible drop and run a negative wedge kit to fix the geometry that get's screwed up in the process.
    Also keep in mind that moving the relocated holes rearward a bit can help quite noticeably too. Not sure if these little towers will allow the 1/8 inch or so of rearward movement though.
    The 4 cars that I've used that mod on dropped the stance at least 1/2 inch and the tires stay much more square to the pavement during heavy turns. Almost seems like going to a larger sway bar and well worth the effort. (y)
  10. 74merc
    1974 Comet
    I'll be doing this as well.
    Car is in the shop right now, might as well.
  11. mercgt73
    I made my own temp-plate, which I assume Bryant will do as well. Came out perfect.
  12. groberts101
    groberts101 Member
    Minneapolis, MN
    Thanks for the pics. Sure looks like there's more than sufficient room for the 1/8 inch setback to me.
    Good to know since I'll be maxing mine out. :)
  13. injectedmav
    injectedmav Member
    Georgia
    I've done both the 2" full drop with the wedges and setback and the 1.5" drop with tubular upper control arms. I was still going through upper ball joints every 15-20K miles. The 2" drop was done with the Pro-Motorsports templates and wedge kit and I had to source the ball joints from them since the holes were drilled for 3/8" hardware instead of the OEM 5/16". I personally prefer the 1.5" drop and if I didn't have the tubular UCA's, I would still use the ball joint wedge, just to be on the safe side.
  14. Dave B
    So, are there any fact's to support the info, that is was already done with the later year cars?
    I have a early 73, without the support on the shock tower to the frame rail, and a 73 with the support, and the placement appears to be the same, and if I compare it to my 74, it's the same again?
  15. Craig Selvey
    They are all the same.
