Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > General Maverick/Comet
Notices
Reply
Thread Tools Display Modes
Old 2013-02-28, 05:34   #1
lightspeed
Member
Vehicle(s): Two 1971 Mercury Comet GT
71 302 engine value $$$$$$$ ???????
i have a 71 302 2bbl. engine ,which is complete from flywheel to starter , and intake,and carb. i pulled it out of my wrecked 71 Comet gt 5 years ago , and it was a running motor then , with 65,000 miles on her.
If i was to sell this 71 302 2bbl complete motor , what would u ask for it , or what do u think the value is????? $$$$$$$$$$$ ???????
i don,t know if this is a regular 302 block or the so called stronger mexican 302 block ???// How do u tell???
i gussing old 68 -72 302 blocks are getting harder to find which might increase value $$$ ??? , but in this day of age u can buy all sorts of very strong aftermarket blocks....
lightspeed is offline   Reply With Quote
Sponsored Links
Old 2013-02-28, 06:29   #2
jmgford
Member
jmgford's Avatar
Vehicle(s): '70 Maverick, '69 Fairlane 351, '12 F-150, '02 ZX2
Images: 18
Sadly, around here, you would probably be lucky to get $150 for it. You could try it on Craig'sList for a higher number or best offer and see what happens.
__________________
Member
jmgford is offline   Reply With Quote
Old 2013-02-28, 07:09   #3
Streamliner
Member
Streamliner's Avatar
Images: 28
New and rebuilt engines and shortblocks have become really reasonable,,,Probably a coupla hundred bucks if you're lucky enough to find someone locally that needs one
Streamliner is offline   Reply With Quote
Old 2013-02-28, 07:49   #4
baddad457
Member
baddad457's Avatar
Quote:
Yup, that's about all it's worth.
__________________
77 Comet, 331 Six-pack, Canfield heads, Z303 cam, repop 3x2 induction w/3 Holley 250's, Hedman long tubes, C-4 trans, 9" rear, trac-loc 3.50's. Cheap Street car. Pics at http://s125.photobucket.com/albums/p53/baddad457/
baddad457 is online now   Reply With Quote
Old 2013-02-28, 07:50   #5
71gold
Frank Cooper
71gold's Avatar
Vehicle(s): '73 Grabber
Images: 45
good price...here 5.0s are 150-$250
71gold is offline   Reply With Quote
Old 2013-02-28, 07:54   #6
baddad457
Member
baddad457's Avatar
The Mex blocks have two bolt bosses cast into the front walls of the block, one on each side below the cylinder heads.The casting numbers also ID them. And there's "Hecho en Mexico" cast into the lifter valley floor. The std 302 blocks from 68 to 79 are just as strong as the Mex blocks. The only difference the Mex blocks had over the std blocks were the thicker 289 Hi-PO main caps. The D8VE-A3A blocks also had these main caps. If it's complete, just as it came from the factory, you can sometimes get more for it by parting it out. But as a whole you'd be lucky to get $150-$200 for it.
__________________
Old 2013-02-28, 13:57   #7
predfan2001
David in Tn
predfan2001's Avatar
Vehicle(s): 70 Mav 75 Comet 64 Comet 68 Mustang
Images: 15
In my experience, you can get as much for carb and heads as you can the whole engine. Throw it on CL for the price you'd like to get then drop it if you don't get any calls.
predfan2001 is online now   Reply With Quote
Old 2013-02-28, 16:24   #8
71gold
Frank Cooper
71gold's Avatar
Images: 45
Quote:
had two on there for...free...the other day...
both sold...
Old 2013-02-28, 18:58   #9
baddad457
Member
baddad457's Avatar
I've got two bare 302 blocks on there now, got a solid bite on both today at $100 each. (Knocking on wood as I type this)
__________________
Old 2013-02-28, 21:56   #10
ESampson
Senior Member
ESampson's Avatar
Vehicle(s): 1974 Comet GT
Images: 22
I sold mine from the 72 this past weekend for 175.. He wanted it for 150 I was firm on 200 but we settled at 175 cuz i know I'd have it sitting around for a while to get rid of a 302.. There just too common.
ESampson is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
