...belly bar bolts...
Discussion in 'Parts Interchange' started by 71gold, Mar 4, 2013.
  1. 71gold
  2. Dave B
    Your link doesn't work.
  3. Craig Selvey
    Shouldn't these be called "V-8 Engine Crossmember Bolts"?
  4. rthomas771
  5. rthomas771
    The crossmember came on 6 cyl cars also. Matter of fact the 1st V8 Falcons didn't have the #2 crossmember but the 6 cyl Falcons did. But the 1st V8 Falcons had a torque box and the 6 cyl didn't
  6. Craig Selvey
    Aren't we talking about Mavericks/Comets? I have never seen a 6 cyl Maverick with an engine crossmember from the factory (though they all had the holes/threaded inserts).
  7. 71gold
  8. 71gold
    Front Tubular Crossmember Bolts
  9. rthomas771
    Actually we're talking about a bolt from a Mustang that fits a Maverick. Both Mustang and Maverick belly bar's have one bolt on each end. the early Falcon had 3 bolts on each end. Which one sounds like an engineer designed? Which one sounds like the bean counters got ahold of. You wouldn't want to build a house with only one nail on each end of a 2x4...so why use a crossmember with only one bolt at each end? Here is a pic of the early Falcon crossmember.
  10. scooper77515
    Can someone confirm that these are the same size as ours?
    I found the link from a local mustang parts supplier, here in houston, but never put my hands on them to verify that they are the same size as our cars'.
    I would hate for a bunch of guys to order them to find they are not the right size.
  11. Dave B
    They are the same.
  12. NICK DOMINICK
    Burke, Virginia
    Thanks for looking this up, everytime I thought about looking it up I forgot. They must be a fairly new item because a couple years ago nobody reproduced them. I actually made my own.
  13. NICK DOMINICK
    Burke, Virginia
    Thanks for the info!! Were the bolts tapered like the Maverick and Mustangs?
  14. scooper77515
    OK, cool! Good to know. And best of all, LOCAL!!! :dance:
  15. rthomas771
    It uses the bolts that hold the frame mounts to the inter shock tower. This is the only pics I got handy...maybe you can see how it mounts. This is an aftermarket belly bar for an early Falcon with a V8
