Maverick Side View Mirror
Discussion in 'Parts Interchange' started by ezdoes123, Mar 17, 2013.
  1. ezdoes123
    ezdoes123 New Member
    NEPA
    I purchased a side view mirror for my 1970 Ford Maverick. The mirror happens to be an adjustable with the toggle at the end of the cable that goes to the inside panel on the driver's door.
    The problem is my car didn't previously have a remote side view mirror. So, I have to find out where to put the hole in the side panel to mount the toggle that adjusts the mirror.
    Thanks!
  2. rthomas771
  3. ezdoes123
    NEPA
    Jeff,
    Thanks a lot for the diagram, however, I should have explained better.
    Because my car never had a mirror that I could adjust from the INSIDE, I'd like to mount it where the factory would mount it. So, I need to know where to put the hole on the inside panel door to mount the toggle.
    Thanks!
  4. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Doesn't view " X " give you the mesaurements you need?
    Rick
  5. 71gold
    did you get the...special washer...
    most of the time it drops down inside of the door when removing the toggle...:yup:
  6. ezdoes123
    NEPA
    I apologize....my wife printed out the document and for some reason only the top part printed. I just looked at it online and it looks like you gave me all the info I need.
    Thanks again!
