Maverick parts interchange by year?
Discussion in 'Parts Interchange' started by harvey echo, Apr 21, 2013.
  1. harvey echo
    harvey echo New Member
    Iowa
    1983 Ford F150 1982 F100
    First question is about windshields. Will four door models interchange with two doors? And will earlier models, such as 1969 1/2 to 1972(2 or 4 door) interchange with 1973 and later models, or whenever a change by year may have occurred?
    The other question are the doors. The door handles of the earlier models are different than the later models, so will all doors fit all models (other than 2 or 4 door) or is there differences that will not allow this.
    Thanks for any response.
  2. rthomas771
    All windshields are the same.
    Different arm rest on the late 73's...crash beam in the later models also. Interior metal finish is smooth on the 76-77's...earlier doors have a texture finish stamped into the metal. Sometime after '74 the window regulator and glass changed.
  3. harvey echo
    Iowa
    Thanks for details. So all doors of any year will physically bolt-on any other year?
  4. rthomas771
    Yes you could swap doors...but you can't swap the guts from early into late doors or late into early...and as you already know two door and 4-door are different size doors
