when things go too good things are bound to go wrong
Discussion in 'Technical' started by Maverick Man, Jul 14, 2004.
  1. Maverick Man
    California
    welp the 75 car was comming along fine and was gonna start this puppy...(thats right craig i was going to start it! :p ) but i just put some gas in the tank and yes... it got a crack in it creating a leak! :slap:
    happy, happy, joy, joy! :mad:
    so my questions is to you guys...
    any good places you know that have replacment / new maverick gas tanks? i seen some online but they list them for 76 to 77 maverick.. what the heck is the differance. i know early maverick have drop in tanks. but whats the differance in a 73 or 75 to a 76-77?
    also any tips on pulling this sucker out, besides the usual disconnect the battery and try not to create sparks :D
    i'm all ears
  2. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    From what I've found, there are no early Mav tanks in production. I've received several requests for them. I've been told that some Mustang tanks can be used with success.
    Just use care removing the lines and wiring to the sender. Don't get impatient with the strap bolts. It's not uncommon for older vehicle straps to be a problem removing as the bolts corrode. Often the straps themselves end up needing replaced.
    The biggest difference with latter tanks are in regard to emissions.
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I had my tank repaired at a radiator shop...wasn't any need to replace it with a new one...
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    (You're talking about 'Maverick Man' here - he doe$n't repair anything. He $imply dig$ a few bills outta hi$ front pocket and buy$ replacement part$.) ;)
  5. Maverick Man
    California
    when you mean early... meaning drop in tanks like 69's to 71 (or when ever they stop making them or are we talking 73 to 76 as early?
  6. Maverick Man
    California
    i presume you took the tank to them right? i mean out of the car.
  7. Maverick Man
    California
    whats repair.. i only recycle.. throw out the old get the new! lol
    besides i saved money buying this car! now i can spend the money i saved on it and buy something else :D like a gas tank!.
    anyone wanna buy some new 18 inch 5 bolt honda rims? i need some more money... lol
  8. Mavaholic
    Tank Differences as I've seen:
    70- drop in. unique to itself.
    71 to 74 -Smaller tank with taper in the rear to clear the rear valance.
    75 to 77 - Larger capacity but still basically the same. The back is squared off to give extra couple of gallons. No valance to worry about.
    The 74-75 is a greay area in the transition period. You might find either in 74 but I believe all the 75's were the larger tank. You can interchange tanks between 71-77 as long as you use the correct straps. The sending units are interchangable too although AK has different listings. They will still work. Since these gauges are a relative measurement anyways, it dont really matter if its a few gallons off.
  9. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Tanks
    Dennis, you used a 60's Mustang tank with the front mounted
    sending unit, correct?
    If I ever switch it will probably be to that since it allows more exhaust
    clearance and is probably cheaper.
    Seth
