Loose Sport Mirror Repair
Discussion in 'Technical' started by rthomas771, May 16, 2013.
  1. rthomas771
    BKelley sent me a youtube link on how to fix a passenger loose mirror. It looked easy enough so I thought I give it a try. Every thing came out as planned except the quality of the cheap Dorman replacement lens. I will be ordering new lens from West Coast Classic Cougar to do this job right. [nomedia="http://www.youtube.com/watch?v=-PQw_J52CU0"]RH Sport Mirror Repair: 69-73 Ford / Mercury / Lincoln - YouTube[/nomedia]
    Here is a link on how I fixed my floppy mirror. http://1bad6t.com/Maverick/maverick_50.html
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Awesome!... Thanks for sharing the repair on a Maverick mirror!
  3. rickm
    rickm Member
    Owosso Mi
    I asked on here about this 2 yrs ago and got very little. Thanks for putting this on, now to the garage and dig out my old one and do the fix. Thanks again
  4. 71gold
    Jeff and I are planning a...work shop...on this in a couple of weeks at my shop.
    I will post when it's going to be.
    I think I have a mirror to use.
    another option we talked about was using rivets instead of screws.
    stay tuned...:yup:
  5. ccheeks14
    ccheeks14 Member
    Portland, OR
    1976 Maverick
    Just read this how-to on Shorthorns. :thumbs2: Where did you get your replacement mirror from though?
  6. rthomas771
    Most auto part stores will have/can get a Dorman replacement lens. I got mine from Summit Racing since Summit is in my neighborhood
  7. 55crownvic
    55crownvic Member
    colorado springs
    Thanks for that video, mine works great now!! One tip from me tho, if your mirror glass is in good shape and are too cheap to get a new one(me!)then try heating the four corners of the metal base carefully and slowly, I used a torch on very low flame, then try and slide a thin putty knife under the edge of the glass and it will release from the back piece un-broken, then once repaired simply dab some goop on each corner and reinstall glass.
