Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Cosmetic
Notices
Reply
Thread Tools Display Modes
Old 2013-08-19, 21:46   #1
redfivexw
Member
redfivexw's Avatar
trim ring size
Can anyone tell me the proper size trim ring to use with the ford poverty caps? I have a 70 with the 4 lug 14" steel wheels, wondering what the proper ring is.
redfivexw is offline   Reply With Quote
Sponsored Links
Old 2013-08-19, 21:57   #2
Dave B
MCCI Ontario Rep.
Dave B's Avatar
Vehicle(s): 3 Grabbers
Images: 34
14" ??????????
__________________
Dave B is offline   Reply With Quote
Old 2013-08-19, 22:49   #3
Acornridgeman
MCCI Wisconsin State Rep
Acornridgeman's Avatar
Vehicle(s): 70 Maverick Grabber, 72 Maverick Grabber Restomod
Stock steel wheels - and on my '70 Grabber they were 14", while some of the early cars had 13"
The trim ring on the 14" is a thinner one than the Mustang and Torino used - if you lay it flat on a table it sticks up about 1 3/4" high. The 2" and 2 1/4" ones will fit on the rim and look fine. But if you are after concourse the thinner 1 3/4" is the one.
__________________
Eric Johnson
Ford Maverick - "The Car Famous For NOT Breaking Down"
Acornridgeman is offline   Reply With Quote
Old 2013-08-20, 07:30   #4
Craig Selvey
Indiana State Rep - MCCI
Craig Selvey's Avatar
Vehicle(s): 1972 Maverick Grabber - Color: Orange Also, 1976 Ford Maverick 4-door, 1977 Mercury Comet 2-door. Daily driver: 2005 Ford Focus SE Station Wagon
Images: 431
To add to what Eric stated, your car being a 1970 means that more than likely it has the 4 1/2" wide wheel. It takes the thin beauty ring. The wider the wheel....the deeper the beauty ring.
__________________
Craig's Maverick Corral: http://www.maverickcorral.com
To email me DIRECTLY, do NOT click on my name to the left and choose an option, instead, email me DIRECTLY at:
Craig Selvey is offline   Reply With Quote
Old 2013-08-20, 20:47   #5
redfivexw
Member
redfivexw's Avatar
thanks for the info, i will order a set of 1.75" rings.
Old 2013-08-20, 20:50   #6
Acornridgeman
Quote:
Original style are not reproduced as far as I have seen.
Post a link to what you are ordering, I'd like to see them.
__________________
Eric Johnson
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
