14 air cleaner on 6 cyl ?? QUESTION
Discussion in 'Technical' started by pattyderome, Nov 14, 2013.
  1. pattyderome
    pattyderome Flying Comet
    Québec, Canada
    Mercury Comet 1976
    I would know if I can put a 14''x2'' air cleaner on a 6 cyl engine 1bbl ? Thanks
  2. predfan2001
    The vintage Mustang vendors sell a chrome hi-po style air cleaner for a 1V carb. I want one but I'd like to know for sure if it clears a MAverick hood first.
  3. pattyderome
    Québec, Canada
    Mercury Comet 1976
    Where can I find this air cleaner ? Ebay ? Thanks
  4. predfan2001
    Scott Drake and NPD. I'm sure many others sell them.
  5. pattyderome
    Québec, Canada
    Mercury Comet 1976
    I dont have found on scott drake and npd.. He has only for a 2v or 4v carbs..
  6. rthomas771
  7. pattyderome
    Québec, Canada
    Mercury Comet 1976
  8. predfan2001
    After re-reading the adds again, it appears that these fit the Autolight 1V. Probably will not fit Carters.
  9. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    If you have a carb like the one pictured here it will not fit without modification. I purchased one of those years ago from mustangs unlimited but it would not clear the electric choke housing. So I cut a hole in the base to fit around the choke and then it fit nice. This on a 250 motor. I still have it laying around the garage as I am no longer running that carb.
  10. pattyderome
    Québec, Canada
    Mercury Comet 1976
    and where you plug this hose on your new air cleaner ?
  11. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    That hose use to go to a spot on the original air cleaner but the new one did not have a spot for it. I just eliminated the hose and put a breather in its place.
  12. Krazy Comet
    Dismal Swamp
    Yeah I'm doing same on my Comet and using a 1967 style cap that twists on but has no hose connection...
  13. rthomas771
    I bought the Scott Drake air cleaner the other day. I had to open up the hole with a Dremel about 3/8" to get it to fit a Carter RBS. I bought an aftermarket oil filler cap that eliminated the hose. The hood clears the shallow base breather. I still need to get the charcoal canister hose attached on the base. Thinking about using the same adapter off the original breather but I will need a 1 or 2" longer hose to get from point A to point B or use some type of 90* fitting.
