Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2014-02-16, 19:51   #1
HarleyGA
Member
HarleyGA's Avatar
Vehicle(s): 73 Grabber, 72 Comet GT
Images: 1
Another 9 inch interchange question
I see an ad on craigslist for a 9 inch rear end. The add says it's 57 inches from flange to flange and little else. Could this be from an early Mustang? What are the other possibilities. I'm hoping to find an axel that would be a direct bolt on. What questions should I ask when I call?
HarleyGA is offline   Reply With Quote
Sponsored Links
Old 2014-02-16, 20:17   #2
bmcdaniel
Senile Member
bmcdaniel's Avatar
Vehicle(s): '70 Maverick Grabber
Images: 6
I believe that's the width of the old Ranchero or station wagon piece. You can ask for the distance between the spring perches.
__________________
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, 625 Street Demon carb, EDIS/MegaJolt ignition, Hooker 6901s), T5Z w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
Some people are like slinkies, good for nothing but they still make you laugh when you push them down the stairs
bmcdaniel is offline   Reply With Quote
Old 2014-02-16, 21:21   #3
mav1970
Bob Hatcher
mav1970's Avatar
Vehicle(s): 69.5 Maverick 393 Cleveland Stroker
Images: 206
Try to find out exactly what it came out of
__________________
Every step of my project has been temporarily impossible
My Insane 1969.5 Street Project Thread
mav1970 is offline   Reply With Quote
Old 2014-02-16, 22:28   #4
dyent
Member
Vehicle(s): 1974 comet
Images: 34
The dimensions for our Mav/Comet housing only, spring perches are 43" center to center and housing flange to flange is 51 1/4".
Early 65-66 Mustang housings are slightly wider at 52", same spring perch.
67-70 Mustang housings are 54" with same spring perches and the 71-73 Mustang housings are 56" wide.
Either way, if that 9" housing on CL is 57", then it is way too wide to fit our cars. Early 65-66 Mustang will fit fine, but locating a factory 9" would be quite rare, unless it is an aftermarket one. The 67-70 Mustang will work, but you will have to get rims that are offset enough to fit within the wheelwells. Ones used on 67-70 Cougars same as the 67-70 Mustang.
Now you have the dimensions for a housing...... 43" perches and approx.
51 1/4 to 52" for width and then there is a question as to what bearing ends, are they the small which is what our 8" uses or the big which where used for full size cars or with big block engines......
You can also get a custom fabricated 9" housing made to OEM specs for around $300, can still use same axles from your 8" too........
dyent is offline   Reply With Quote
Old 2014-02-17, 00:53   #5
baddad457
Member
baddad457's Avatar
Is that 57" figure the distance from axle flange to axle flange, or the width of the housing between the flanges ? All Ford leaf sprung cars used the same 43" spring pad spacing, so if it's a car 9" then it'll bolt up, the kicker is the distance from axle flange to axle flange.
__________________
77 Comet, 331 Six-pack, Canfield heads, Z303 cam, repop 3x2 induction w/3 Holley 250's, Hedman long tubes, Toploader , 4 speed hydraulic clutch, 9" rear, trac-loc 3.50's. Cheap Street car. Pics at http://s125.photobucket.com/albums/p53/baddad457/
baddad457 is offline   Reply With Quote
Old 2014-02-17, 01:14   #6
dyent
Member
Images: 34
If it is 57" from axle flange to axle flange (outside face of where rim mounts onto the axle), then it is the same as our Mav/Comet. You would then have to check and measure that the spring perches are 43" center to center distance. One other thing to check is the bolt circle on the axles, 5 bolts on 4 1/2" circle, providing this 9" does come complete with axles.....then the questions, what was it in, is this OEM or aftermarket/modified, gear ratio, posi or non posi, how many splines on axle 28 or 31 or other, does it come with brakes, then you have to check to see how much, if any play there is, the list can go on and on.........good luck!
perhaps you could post the link to that Craigslist ad for us to see, maybe can give you better info before you purchase.......
Old 2014-02-17, 20:39   #7
bmcdaniel
Senile Member
bmcdaniel's Avatar
Images: 6
Quote:
That's what I have in mine. Had the rear wheels widened 2" towards the inside so now they are 15 x 8 with 6" back space.
__________________
Old 2014-02-17, 20:56   #8
Dave B
MCCI Ontario Rep.
Dave B's Avatar
Vehicle(s): 3 Grabbers
Images: 34
Quote:
That's good to know, since I'm working a deal on one out of a 68 Mustang.
__________________
Dave B is offline   Reply With Quote
Old 2014-02-18, 07:59   #9
HarleyGA
Member
HarleyGA's Avatar
Images: 1
Thanx to all. Lots of great information. I was confused about how overall width was measured. Good to know the center to center width of the spring perches but do they all accommodate the same width spring? Finding a nine inch with the right dimensions has so far been tough. I don't really care about the axle shafts, unless they are 31 splines. Same goes for the center chunk since this will be replaced with a 3:55.
Old 2014-02-18, 14:25   #10
dyent
Member
Images: 34
Quote:
another option, you can check out this link:
http://www.ebay.com/itm/9-Inch-Ford-Rearend-Axle-Housing-65-66-Mustang-Axle-Rear-End-/221248278358?pt=Motors_Car_Truck_Parts_Accessories &vxp=mtr&hash=item33836ccf56&forcev4exp=true
I had my 9" custom made by this same fellow to the exact same specs as our Mav/Comet that I first mentioned earlier. Totally brand new, excellent quality and built to take whatever you throw at it, much stronger than any OEM stuff. You can also have complete packages made up, so just check out their site.
Finding something used is great, but you really have to check out that everything is OK, who knows what kind of abuse it has been through and sometimes it is better just buying new.
Spring perches pretty much all the same and will work with all of our Mav/Comet leaf springs. Passenger cars, like early Mustang/Cougars etc., will work fine, but watch out for ones in early Bronco's since their perches where attached to top of axle tubes, passenger are attached to the bottom of the tubes.
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
