1/2 quart over full on oil will this hurt?
Discussion in 'Technical' started by Russ, Jan 28, 2006.
  1. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Changed the oil in the 73, 250 this weekend and somehow ended up 1/2 q. over full. Should I worry about this? or will it be ok until the next oil change?.
  2. 71gold
    russ,
    what i do is take the filter off and drain it...screw it back on... that should be 1/2 quart...frank...:bouncy:
  3. Mavaholic
    I doubt it would hurt anything but if your worried, Frank has a good plan.
  4. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    :wave: Hey Russ, I would rather run a engine a 1/2 qt low than a 1/2 qt. over full.I'm a firm believer that the excess oil has got to come out somewhere....usually the front or rear seal.If your car has any sign of even the smallest of leak...I would probally say,"It'll be OK......Most cars makers today saw the light of this situation and provided a maximum over fill mark on the dipstick.If your motor is leak free especially, freshly rebuilt(new rings)...It could do more harm than good,especially at high speeds(rpms).Good Luck,Hotrod-Daddy(y)
  5. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    You could also loosen the oil pan drain plug. Dunno which would be messier, unscrewing the oil filter or drain plug. :confused:
    Personally, I wouldn't worry about it (and deal with the consequences later) ...... :drink:
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    In the old days I used to run an extra qt of oil in mine, just cause I was so hard on it, specially at high RPM,s. Old timer told me as hard as I run a car I should run extra oil,, dont think it ever hurt it. Nowadays,, I keep everything right on full.
    Dan
  7. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    1/2 wont hurtI run 1/2 quart over in the mav just to be safe.
    1 quart over is pushing it IMO. Crankcase pressure starts to rise and increases chance to develope leaks.
  8. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    Thanks for the replies. I don't think I'll worry about it right now. If I get a chance and it's nice out next few weekends maybe I'll pull the filter and drain it. I guess I should have let the old oil drain a little while longer. I was concerned about the over full getting to the crank but I don't think a 1/2 q will get that high. Russ
  9. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I wouldn't worry about it...
  10. 71gold
    mine is a 1/2 quart over on the full mark. when i change my oil it is at the full mark and the motor blows a 1/2 quart out. after that not a drop less.:huh:
    ...frank...:bouncy:
  11. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    Frank where does the extra go out a seal or tailpipe?
  12. 74merc
    74merc computer nerd
    1974 Comet
    Mine was the same as Frank's.
    Mine blew it out of the dipstick tube and vent on the valve cover. Didn't do it unless it saw over 4000rpms. One of the reasons I'll be building the engine. Compression rings are going south.
    On topic, I wouldn't worry about it.
  13. 71gold
    i think out the seals, valve cover vent and dipstick tube. keeps my rear bumper from rusting :yup: . only does it when i tear into it hard :rolleyes: ...frank...:bouncy:
  14. 74merc
    1974 Comet
    Yea, automatic undercoating. :)
