1/4 plastics
Discussion in 'Cosmetic' started by Joe Dirt, Mar 18, 2010.
  1. Joe Dirt
    will 70-72 1/4 plastics bolt in my 74 with no issues other then the seat belts?
  2. yellow75
    Tillamook Oregon
    The back seat is different on 70-71 due to seat belt location, if you use the panels from a 70-71 there will be a mismatch at the seat bottom
  3. Joe Dirt
    good deal then they should fit my car fine! Ive got a rear seat delete
  4. brainsboy
    brainsboy Member
    Tampa
    You should note also that the rear seat belt bolt holes are in different spots.
  5. Craig Selvey
    They are also different at the bottom where the 1974 panels slide in beside the seat belt assembly. 1970-1972 units will not do that. You can still make it work though.
  6. yellow75
    Tillamook Oregon
    Oops I forgot about you having rear seat delete, then the only problem you will have is the post that stick up that hold the seat belts on the side behind the surround area, cut them off if you havent all ready and 70-71 will fit just fine and not have holes in them for seat belts :thumbs2:
