1 bbl holley air intake
Discussion in 'General Maverick/Comet' started by Eastern Raider, Sep 25, 2011.
  1. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    Just put a 1 bbl. holley carb. on the six cyl.The one with the bowl on the side . This carb. really wakes up the six. The carb. does not have a air filter bolt provision . Awsome acceleration, but it must use a 3 inch v- band clamp,:hmmm: like a turbo tube clamp. There are kits on ebay-air tubes ,would any one have experience with this set up on carbs? What can you recomend?
  2. Eastern Raider
    Ok found out that this type carb is used on cj6 jeep,international harvester truck,ford, and smith air compressor. the best chance of an air intake would be the jeep with the clamp.:thumbs2:. This 1904 holley is awsome on a six cylinder!
  3. rthomas771
    '60 Falcon had this clamp too, '61-up didn't
  4. Eastern Raider
    Thanks man, I will look that up. The six cyl. is down for slack in the drive train. Im checking the rear axle gear. I hope to be at the summit meet in early Dec. Mabey also in silver springs fla ., January.:thumbs2::comet:
