1 step closer to on the road
Discussion in 'General Maverick/Comet' started by Bob Wiken, Nov 19, 2010.
  1. Bob Wiken
    Fayetteville, Arkansas
    Yesterday got a coat of rattle can "Ford grey" in my engine bay. also , Tuesday, a new battery trey. Motor is just about ready to install. I need to clean up the p/s pump, fuel pump and alternator and drop that sucker in. I hope it goes in as easily as it came out.
  2. maverick75
    Sounds good. We need pics :)
  3. Bob Wiken
    as requested
    in the 2nd photo you can see the quality work of the PO. If you look closely in the 5th pic you can see the repair (about 1:00 above the torque converter, right in the "C" formeedn by the brake lines. I am waiting for a friend to get me a hole saw to cut the new hole
  4. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Ford gray looks a lot like primer. With clearcoat. :D
  5. Red Rooster
    Red Rooster 302 and C4 Rebuild done:)
    San Antonio, TX
    74 Comet GT
    1 step closer
    It is a great feeling to hear it when it cranks. . . patience is important to get things right the first time.
    Great to hear of your progress.
    See you on the road.
  6. mercgt73
    Looking good! Good luck on the engine drop in! (y)
  7. Bob Wiken
    A young friend came over this aft and we droped it in. motor mts are finger tight, 4 bell housing bolts finger tight.
    I just checked and the torque conv. bolts are dragging. I do not want to pull that engine all out again. hopefully i cvan put in some long bolts into the block from the bell and get enough room to turn TC to line up with hioles. It got too cold and dark to work and now...,.
    it's Shiner Bock time. He's coming back tomorrow
    he has an 87 Capris? It's like a fox body mustang
