1 wire alternator...
Discussion in 'Technical' started by PINKY, Nov 16, 2004.
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I am assuming that everyone is a little different, but do they all need a ground wire ran on them. I was reading one of my mags and they did this swap and they ran a ground wire to the block.
    Is this the general rule of thumb?
  2. Mavaholic
    That kind makes it a 2 wire, dont it?
  3. 71gold
    kinda...but you can't have too many "grounds"....frank...
  4. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    they are grounded through the case to the block, no need for a ground wire
  5. Acornridgeman
    Wisconsin
    I have put 1 wires on everything from cars and trucks to road graders and boats, and have never needed an extra ground wire.
    Eric
  6. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    I was trying to do a 3 wire with a larger alternator and I failed because of the case size. The 1 wire seems to be the way to go and most are grounded to the engine block.
    If you have the November issue of Mustang & Fords, they have a pictorial install of a 1 wire conversion 130 amp alternator. I intend to go with this one if the case is the same size as our's are.
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Wes, give Rick Harmon a call at PA Performance 1-877-471-8010
    http://www.pa-performance.com/
    I purchased an alternator from him in August. He is great to deal with. Their theory is there is really no such thing as a one wire alternator for a Ford. They utilize an additional 12v switched wire to turn on the regulator. Most one wire alternators require the engine to be revved up in order to turn on the regulator.
  8. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    with the rubber in the mounts the engine might not get a good ground all the time
  9. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    Well....hmmmm wonder why they grounded theirs?
    Mine is relocated and it is held down by aluminum motor plate and a chrome brace.....just wondering.
    Thaks for all the input.
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    not running motor mounts.;)
  11. MaverickGrabber
    Cardington, ohio
    yeah but the Mag dont know that and they cover there butts
  12. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    true very true
  13. Mavaholic
    Thats why your supposed to run your battery cable to the engine block.
  14. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    John, I like how you have it mounted down low!! Did you ever have it tested to see if it's putting out power?? They do make a rebuild kit that will up the amperage........
  15. MaverickGrabber
    Cardington, ohio
    they are but some when they move the batt to the rear just ground it to the body :slap:
