10650 orginal miles
Discussion in 'General Maverick/Comet' started by rick 1, Feb 3, 2010.
  1. rick 1
    rick 1 New Member
    pottsville pa
    71 maverick
    need some help i am trying to find how to authenicate a 71 maverick it has 10650 org miles has not been on road since 83 all orginal paint very good interor perfect. still has orginal tires. bought from orginal owner
  2. Earl Branham
    Lugoff, SC
    Maintenance records are the only way you can find out.
  3. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    also if you look at the odometer and all the numbers are even across it thats a good sign if they are uneven its been flipped over.
    my low milage is documented on my title and it says actual milage and the car has not been plated since 1974.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    If it doesn't look like it only has 10K miles ... then it really doesn't matter if it does or doesn't. I'd rather have a sweet and care for 100K mile car than a ratty 10K mile car ...
  5. 71gold
    that just means everything on it is...39 years old....and needs to be replaced...
  6. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    The problem as you probably know is in PA. any older veh.,they just put milage exceeds mechanical limitation of speedometer (or some silly thing like that!) on the title, and if you have a true low milage car it's hard to get the title corrected...
  7. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    With that mileage, there should not be any wear on the steering wheel (paint). Rubber pads on the brake and fuel pedal should not have any wear.
  8. 71gold
    :hmmm:.....................................:rofl2:
    ...:sorry:...
  9. Acornridgeman
    Wisconsin
    All good advice so far .... (y)
    A car with that low of mileage should have many original parts that it left the factory with that otherwise would have been replaced on a car with 100,000+ miles. Look for the original Autolite date coded plug wires. Factory hoses with the factory clamps. Original major parts like alternator, starter, radiator, carb, ect.... would all be good clues.
    The interiors really give it away. As said, look at the rubber on the pedals and especially look at the door sill scuff plates and seats. One of my cars was parked around 1984 and only had about 12,600 miles on it and the interior looked like new once I cleaned the dust off it.
    Post some pictures.
    :thumbs2:
  10. Ol Maverick Man
    Wallingford, Ct.
    Frank, I couldn't think of accelerator pedal.
    Bill
  11. 71gold
    i use...gas pedal...
    (mash the gas pedal...step on the gas pedal...hit the gas pedel...stomp the gas pedal...etc. etc.)...:yup:
  12. d2dz
    d2dz Member
    If this is the red maverick that was posted on the PA Craigslist a while back, then it was discussed in a previous thread within the last month. I think the consensus was that there were a lot of questions concerning the actual mileage. Take a look for the past thread.
    Ed
  13. GrabberJoe
    GrabberJoe Member
    Brooklyn, Michigan
    1974 Maverick Grabber
    There should not be to many signs of ware and tear. Seats, armrest, carpet, steering wheel and horn pad, pedals, ash tray still clean. Check doors and hinges for tight operation, trunk and hood. Check glass for Ford script and side windows for up/down operation. Orginal spare tire/jack still in trunk? Air in spare? Engine compartment: orginal belts, carburator, engine decals, oil filter, radiator/hoses. Take a good look at nuts and bolts, sometimes you tell if a socket or a screwdriver was used. Buying from the orginal owner and having the orginal tires is a good sign! Mabe pop a wheel cover off to see if any lugs are rounded. I know the orginal battery is gone but you can check to see if the cables and connectors are Ford and not aftermarket replacement.
  14. rick 1
    rick 1 New Member
    pottsville pa
    71 maverick
    10650 miles
    thanks for feedback the car has the organal hoses. belts. tires. brake and gas pedal no wear on them interior is perfect no wear no marks never been painted or hit .have orginal title from 1971 from nj with orginal qwners name on it never transfered the question i get is the front of the rad support is painted black i say it from the dealer in 71 because the car is undercoated and they hid the overspray the .car last was on road in 83then put in garage. thanks
  15. Dave B
    Post some pi'c I'd like to see it. I once turned down a 4000 mile Maverick..I regret now...
