15inch fan for a v8?
Discussion in 'General Maverick/Comet' started by shaneb, May 22, 2011.
  1. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    Will a 15 inch fan work good enough to cool a 302 or do I need a bigger fan? The stock water pump fans are only what 17-18 inchs? Please let me know.
  2. jschira
    jschira Member
    How many blades?
    A 6 blade 15" is better than a 4 blade 17".
    A/C or no A/C?
    If you have A/C put on the biggest fan that will fit and a fan shroud. You will need it in TX.
    Highway or all stop and go?
    If all you do is run up and down the highway at 60 mph, you don't really need a fan at all. But stop at a red light for a minute or so in 100* heat, and you can watch your temp gauge climb. 2 or 3 long lights in a row, and the temp gauge will be maxed out.
  3. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    Its a 6 blade 15inch. I dont have an ac or a fan shroud. I will be in stop and go traffic sometimes.
  4. jschira
    jschira Member
    You will probably be OK.
    A fan shroud will do you more good than a 17" fan.
  5. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    ditch the mech fan and go a cheap 16" electric
  6. mojo
    I wud go w/ one or two of the abv mentioned ideas. I think a shroud is the best bet if ur stickin w/ the mech fan; if for no more than a safety issue. Workin on a car w/ the engine running and no shroud - "Is an accident waitin to happen".
    Not to mentioin it will do a lot more to increase coolin efficency.
    I chose to go w/ the elec fan on my car, but everyone has his/her ideas on upgrades. I have a seven blade fan sitting on my garage floor. If ur interested pm me.
