1970 Maverick 4 link coil over rear suspension.
Discussion in 'New Members Forum' started by Shadow750, Apr 14, 2023.
  1. Shadow750
    Shadow750 Member
    NC
    Hey All, Im doing a Maverick restomod and I'm very confused about all the bolt in coil over rear suspensions. I could really use some help in choosing one. Some look so complicated and others look too cheap. Im not a burnout guy or drag or road racer. Im using a 9 inch open rear. I do want adjustable shocks and ride height though. I'll be putting on disc brakes too. Any suggestions would be greatly appreciated.
  2. bmcdaniel
    If all you're concerned with is adding adjustable shocks you could just relocate where the tops of the shocks mount. Get rid of the mounts that are just attached to sheet metal, weld a round tube between the "frame rails" (better yet, through the frame rails), and weld shock mounting tabs to that.
  3. Shadow750
    Shadow750 Member
    NC
    Thnaks but I want to add a full 3 or 4 link setup that attaches to a 9 inch rear. I have scrapped the entire driveline 6 cyl stuff. They make so many for Mustangs, Falcons and Fairlanes but dont say what fits Mavericks.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Tannersg1, Russell and Maverocket like this.
  5. Tannersg1
    Tannersg1 Member
    Classified
    You either have to make your own or order it from Art Morrison, Checkered Past or Chris Alston and make it fit.
  6. Tannersg1
    Tannersg1 Member
    Classified
  7. RMiller
    Kennewick, WA
    RRS does offer a kit, I posted a link to it in the response you quoted.
    Tannersg1 likes this.
  8. Tannersg1
    Tannersg1 Member
    Classified
    I guess you did....Ooops
    RMiller likes this.
  9. RMiller
    Kennewick, WA
    In a sense you're right though, theirs is a torque arm, not a four link!
  10. Tannersg1
    Tannersg1 Member
    Classified
    Exactly what I was getting at lol
    RMiller likes this.
  11. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    I'm a fan of torque arms in upgrade/retrofit situations. They don't bind like a triangulated 4 link can at the extremes of suspension travel. That's why they're a common upgrade for Fox Bodies. A 3 link with proper geometry can intrude severely into the rear seat area. The S197 Mustangs ran a 3 link. It was better than the SN95 4 link, but still suboptimal. Torque arms can be retrofitted to almost any older car with attention to make sure the crossmember leaves enough room for exhaust. In that respect they're significantly better than a truck arm setup like the ones made by Hot Rods to Hell. The selling point on truck arms was that stock cars ran them, therefore supposedly they're a performance suspension. Thing is, no race car anywhere runs truck arms unless the sanctioning body makes them do it.
  12. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Speedway has some universal 4 link kits. I'd think if you can fab and weld at all would work pretty well. They use similar kits for air ride.
