1988 302 project
Discussion in 'Maverick/Comet Projects' started by Thomas, Aug 25, 2012.
  1. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    I am working on putting a 1988 5.0 ho 302 into my 73 Maverick.
    I will have a manual fuel pump, carburetor, holley 1850, stock heads. It originally had serpentine belt reverse rotation water pump.
    I am getting stuck on how it all works being reverse rotation.
    If I want to go with v belt running alternator, water pump.
    do i install a standard water pump?
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Yes, you will need to use a standard rotation for the v-belt.....
  3. Ryan
    Ryan Ford Addict
    Phoenix Az.
    What oil pan is on it now? Dosnt look like a front sump that you will need. Also going to need to adapt the dipstick tube into the front timing cover.
  4. Bryant
    sense putting on a mechanical fuel pump you have to change the front cover to one with the fuel pump provision in it. you will also need to put the drive eccentric thingy on the end of the cam to drive the fuel pump.
    the timing cover is a factor on what rotation water pump to use. so if you want to go with v-belts then get a standard rotation water pump and timing cover
  5. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    I have a 74 302 that I am using for some parts. i have the front sump,oil pan,and oil pickup tube, timing chain cover. I figured I would also change the eccentric on the timing chain to pump the fuel pump.
  6. Ryan
    Ryan Ford Addict
    Phoenix Az.
    And Thennnnn..... Plus you are going to need a maverick style water neck or come up with a custom hose to use the Mustang water neck thats on there. Make sure you use the later Mustang 50oz. balance harmonic balancer. and use a matching 50oz. flexplate or flywheel that will adapt to whatever trans you are running.
  7. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    Oh yes. I was looking at that water neck on the 5.0 sticking straight up like that. I am swapping that as-well. I have a 50oz. 157 flex plate with 10.5 bolt spacing for the tork converter.
    I was thinking of going with the tork convertor and c4 from the existing 250 inline.
    i do have another c4 from the 74 comet as-well.
  8. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    Took the 250 out a couple days ago.
    Here is what I have. I'm going to paint the engine bay flat black.
  9. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    Finished painting the engine bay today.
  10. Paul Masson
    1971 Grabber
    Looks great, Thomas! Nice satin-sheen to the black! :thumbs2:
  11. Mercurycruizers
    Venetia, PA
    :thumbs2:Looking good...
  12. grabberguy16
    grabberguy16 Member
    Courtenay, BC, Canada
    72' 2dr Maverick,70' 2dr Maverick
    Looking good thomas
  13. 71gold
    glad you changed your mind about the flat black...it's a boy dog to clean...looking good...:thumbs2:
  14. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    Making some progress.
    Engine is going in.
  15. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    I have some hooker headers 6901 going in. I will install some old ones now for the engine break in and swap later.
    I don't know what the little extra pipe is for on the header? I was thinking of cutting it off.
    There is also the bracket on the engine mount. I don't know what it is for? I would like to remove it if there is no need for it.
    Anyone know?
