2 bbl swap. is it worth it?
Discussion in 'General Maverick/Comet' started by chevyandford71, Dec 12, 2010.
  1. chevyandford71
    chevyandford71 Member
    Apex, NC
    1971 Ford Maverick Grabber, 1991 Honda CRX HF w/B18A1 swap, 2001 Honda CR80R
    ive been thing of doing a 2bbl swap on my 250 i6 and have read the tech article about it. is it worth it? have you done it?
  2. supermav
    supermav Member
    clarkston wa.
    71 grabber,65 galaxie drag car,66 fairlane 2 door hardtop,64 falcon ranchero
    i have been thinking the same thing. not sure what carb is best to use.
  3. predfan2001
    I've been thinking about it....with a Motorcraft 2100. They are one of the best carbs ever imo as far as dependability goes.
  4. mean_maverick
    i agree...
  5. maverick75
    Next year its on my to do list for the 200. Its also getting a cam from Delta.
  6. tim keck
    sharps chapel,Tn
    I think with the 250 hood clearance is tight. I put a Pinto type 2bbl on my old 300 in my '75 F100. It idles much smoother and the extra "kick" is similiar to a 4 bbl kick on a v8. I like it, but it seems to use more gas than the old 1 bbl.
  7. chevyandford71
    Apex, NC
    i think there is a link on the tech article, i was also going to put a header from classic inlines and an alloy dress up pack, need to sell my go kart first though....
  8. tweet66
    tweet66 where am I?
    Pennsauken, NJ
    I did it a few years back on my 65 Falcon with a 200. I swapped a Duraspark dizzy at the same time. It was the best thing I did to that car. Better throttle response, mileage, and power. I'm getting ready to do it again on another Falcon 6. The adapter was $45 from Summit.
  9. predfan2001
  10. chevyandford71
    Apex, NC
    wow because the adapter on the tech article is from summit and its only 13.00
  11. PaulS
    If you want to get the most from your two barrel swap use a 2Bbl to 2 Bbl adapter and have the manifold cut to the same oval opening as the adapter. Putting a 2Bbl on and keeping the round hole in the manifold won't increase the flow much at all.
    Try here: http://www.jegs.com/i/Trans+Dapt/969/2086/10002/-1
  12. predfan2001
    Yeah I've heard all of that before....but I don't plan on running my 250 inline 6 in the NHRA.
  13. tweet66
    tweet66 where am I?
    Pennsauken, NJ
  14. PaulS
    You might as well just put a single barrel on it then - the hole in the manifold can only flow so much air and putting a larger carb on it is the same as running a four barrel carb on a two barrel manifold.
  15. chevyandford71
    Apex, NC
    what if i didnt cut the manifold and just use the adapter (i know your going to tell that thats just like running a 1bbl) but could it possible work?
