2 gauge battery cable
Discussion in 'Technical' started by Racer_X, Mar 29, 2012.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    When relocating the battery to the trunk do I have to use a 4 gauge positive battery cable? Could I use 2 gauge instead?
  2. injectedmav
    injectedmav Member
    Georgia
    Sure. Don't see a problem.
  3. simple man
    simple man Member
    Bunnell,Florida
    Bigger is always better, where wire size is concerned! :thumbs2:
  4. Joe Dirt
    O or 2 is the only sizes i ever use in a relocation bigger is better
  5. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I read an article a couple years back that said to get wire with the most amount of individual strands in it. Flexibility will be higher and current carrying ability goes up. The theory is that given the same gauge wire the electrons travel on the outermost section of the strands and having more smaller wires conducts better than less wires of a thicker diameter. Just something to consider if you are comparing two of the same gauge wires with different numbers of strands.
  6. mojo
    I believe that's what's called the "Skin Effect".
  7. don graham
    Can't remember wether mine was 0 or 2, but I did get it at my local welding store.:)
  8. Racer_X
    North Carolina
    dose lowes have any?
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    That's what I have always used in the past, welding lead.
  10. ptpdub
    ptpdub Member
    canada Sk.
    x2 welding cable
  11. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Thanks Mojo, I believe you are correct!
  12. mercgt73
    Skin effect is not present in DC current. Skin effect is a function of frequency, which is 0 in DC applications.
    The main reason for stranded wire is the flexibility. If large gauge wire was not stranded, it would be a bear to use.
  13. mojo
    U are correct abt skin effect being a product of AC and frequency. Thanks for the correction. I never thought the effect was only a AC product.
