2 inch lift for my maverick?
Discussion in 'Technical' started by 76stallion, May 20, 2004.
  1. 76stallion
    76stallion Member
    new york
    1976 maverick stallion
    Hey guys, my maverick is sitting alittle low in the front and i wanted it to sit about 2 inches higher. I was wondering if you new any springs that i could pull out of a different car and set in it, or any good little lift kits for the front with stock springs. Thanks alot
  2. bmcdaniel
    Some of the Mustang houses sell extra thick insulators for on top of the springs.
  3. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    what engin do you have ?
  4. Comet-73
    Comet-73 Member
    lethbridge AB Canada
    73 comet gt, 76 comet 4 door, 71 Maverick 200/I6
    Im guessing its the 8 because its a stallion
  5. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    The Stallion package was nothing but cosmetics. Any engine could be in it. The same with Grabbers. It is a common misconception...
    -Corbin
  6. Comet-73
    Comet-73 Member
    Ok thanks, like i said that was just a guess. Also this is just my opinion is that usely if you were to buy the sport pakage you would buy the bigger engine but i know there are exceptions.
  7. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Figure your springs are 30 yrs old. Which means they're weak. Replace them. Not much fun, but the right way to fix it. But you can change the spring rates. There is springs that are for 6, V-8s and heavy duty. Find out what you have and go from there. Shiming up old springs will only increase the chance of bottoming out on the coils.
  8. elliot
    elliot Member
    Boubon MO
    I was thinking that some one put in a V8 but left the I6 springs in it :confused:
  9. bmcdaniel
    I've been running 6 cylinder springs with a V8 for over 30 years now. No problems, sits a little lower, and I like the softer ride the weaker springs give.
  10. 76stallion
    76stallion Member
    new york
    its a v8 in my maverick and there the original springs because my dad owned the car before me and he never changed . Thanks for the help tho
