2 line modulator
Discussion in 'Transmissions' started by Taxi Rob, Nov 20, 2007.
  1. Taxi Rob
    Taxi Rob Member
    San Diego, CA
    1972 Comet 200ci coupe
    What to do? Swap for one line unit? My car still has the two hard lines coming down from the engine, why should I/should I not use them? I know what you're all gonna say, but why does it have two in the first place?
  2. PaulS
    The smaller (front) line is controlled by the EGR. It was a mistake by Ford and it causes problems with the transmission if the EGR fails. Remove the smaller line and plug it at the EGR valve. Use a Green Stripe Modulator to replace the two line unit. Don't make any adjustments to it. If you don't have a 1 5/8" pin in the modulator then make one from an 8d nail. You will be very happy with the way it shifts.
