2 mav tail lights as one ?
Discussion in 'Technical' started by 302-72-mav, Mar 10, 2010.
  1. 302-72-mav
    302-72-mav Member
    sactown CA
    has anyone put 2 maverick lights together as one tail light but without the center reverse lights ?? :huh:
    that's what i am thinking of doing
  2. 302-72-mav
    302-72-mav Member
    sactown CA
    what should i use to weld/soldier the 2 together after that i plan to apoxie the back to make it stronger then bond the front till it's straight then paint it
    i rember some one's post doing something that involved something like that but i cant find it
    it's like this one i'm not sure if i want the reverence lights tho img_0748_original.jpg
    and i'm going to have the center of the mavs lens light up to
  3. 19BlacK77
    19BlacK77 Member
    Wouldn't it just be easier to buy a set of bobcat tail lights? They are exactly what you are wanting and you wouldn't have to do any fab work.
  4. 302-72-mav
    302-72-mav Member
    sactown CA
    cant find any // and i have few sets of mav light just lying around
    and i can say they are maverick tail lights not chevy of mercury ??
  5. scooper77515
    A couple of guys have done it. And I think there is a writeup about doing it on here somewhere.
  6. 71gold
    ...but they will be...Pinto...:yup:
    ...:D...
  7. 302-72-mav
    302-72-mav Member
    sactown CA
    i maid one yesterday and this is how it turned out
    i welded the light bulb holder in the center of each housing so that the whole light will light up
    i might leave them chrome if i get the seam on the other one good like the first one
    before i moved them
    after the bulb's housing was moved
    [​IMG][​IMG]
    with some cocking on it
  8. maverick75
    Those turned out good:thumbs2:
    The seam trick is sweet!
    Nice alternative for those who cant find bobcats...
    I got lucky one day and found a pair...
    These are pretty cool also...
  9. 302-72-mav
    302-72-mav Member
    sactown CA
    i did it
    here you can see that i put the light bulbs in the center of the lights
    I WILL POST PIC'S OF WHAT IT WILL LOOK LIKE WHEN IT IS DARK when it gets dark outside
  10. 302-72-mav
    302-72-mav Member
    sactown CA
    yup yup
    running lights
    with brake lights on
  11. FastMav5
    FastMav5 Member
    Illinois
    Sweeeeeet!
  12. Mavaholic
    How did you join the bezels together?
  13. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    tail lights
    thats trick!(y)
  14. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    tail lights
    if those light are [seqential]...... that's TRICK!:thumbs2:
