225/60r15
Discussion in 'Wheels and Tires' started by Trojan, Apr 1, 2013.
  1. Trojan
    Trojan Member
    Bakersfield California
    1972 Mercury Comet
    So im planning on getting some 225/60R15 bf goodrich T/As but was wondering if anyone else had em or was planning on doing the same?I have some 225/50R15 BFs on the back right now and they would rub the lip of the fender but im planning on getting bigger fronts to prevent bottoming out so i would need bigger backs to even out the muscle car stance. Would the 225/60R15s fit with rolled fenders?
  2. Dave B
  3. Craig Selvey
    You need to see if they will fit those 10" wide wheels...let alone the car.
  4. scooper77515
    You have 225s rubbing on the BACK?
    Post up your rim sizes.
    I have 225/60-15 on front, no issues, and 255/60-15 out back with rolled lips (cut into tires on hard launches before I rolled them).
    I see no reason 225 in the back should be a problem, unless you have horrible offset rims.
  5. 71gold
    I ran 275X60X15X8 no rolled fenders and no scrub...:hmmm:
    running 255 now no problems.
  6. Craig Selvey
    I think we have a winner!!
    From a previous post, he has deep dish 15 x 10 wheels.
  7. Trojan
    Trojan Member
    1972 Mercury Comet
    Hold on,the first three numbers of this are width right?(225)/xxRxx or are they the hight?cus i want something higher for the backs,what it has right now is the 225/50R15 and i just want something higher
  8. 71gold
    wrong offset and too wide of a rim can cause rubbing/scrubbing...:yup:
    My 275X60X15 were on 8" rims.
  9. Craig Selvey
    Here is the rim he is working with.
  10. scooper77515
    225 is width, the /60 is height (ratio, not millimeters) so those heights are 60% of the width.
    I run 225/60 on 15x7 up front, and 255 on 15x8 out back.
  11. Trojan
    Trojan Member
    1972 Mercury Comet
    man the initial tire sizes were off,i musta been tired XD well im running the old Lincolns now with 215/70r15 front and back,havent tried to mess with the daisy mags running 275/50r15s,but im down to either 295/50r15s or 275/60r15s for the backs and still no idea for the front 14x7s. ill update progress when more money comes in :p
  12. jackieblue47
    jackieblue47 Member
    mich
    1973 grabber maverick 1977 grabber 1966 mustang coupe 1989 ranger drag truck 2012 f-150 fx2 twin turbo
    I'm running 275/60/15 nitto drag radials on 8 inch rims 3 3/4 backspace no problems with clearance
  13. Trojan
    Trojan Member
    1972 Mercury Comet
    thanks man,sounds like i should be good then :p
