26x19 Radiator install DONE!!
Discussion in 'Technical' started by 71_Maverick, Oct 13, 2008.
  1. 71_Maverick
    71_Maverick Member
    michigan
    i just finished putting in my new radiator.26x19 aluminum with 2 1.5 inch cores. im pretty sure this is the biggest radiator you can fit into the stock location.
    i had to cut and trim some metal at the bottom so it could sit low enough for the hood to close. i also fabricated some mounts top and bottom. i put my stock mechanical fan and shroud on for now until i can get a electric fan im going to get a polished cover to sit over the top and cover the brackets and stuff up but i think you looks pretty nice.
  2. don graham
    Looks good. What brand radiator is it?:)
  3. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Looks like my Griffin. Install sounds the same.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Looks good, I have the same size radiator in mine right now. Mine is from Northern Radiator.
  5. don graham
    I've also got the Northern in my 71. Works good. My only complaint is there's no drain petcock. I have to loosen the lower hose to drain it. Kepp saying I'm gonna get one put in.:)
  6. rthomas771
    My Griffin doesn't have a petcock either. I use a small drill pump on my cordless drill
  7. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    been there done that....congrats!
  8. maverick1970
    Missouri
    Same here, don't know what they were thinking. I thought about installing an in-line drain such as this.
    http://www.jegs.com/p/Flex-a-lite/1017700/10002/-1
  9. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Mine is similar, and I use a heater hose as a siphon. At least antifreeze is tasty...
  10. PaulS
    It looks to me like the only problem is that the fan is on backwards.:rolleyes:
    Maybe I am just looking at it wrong but if it is on backwards it wont pull as much air at an idle
  11. Bryant
    hey paul your right it looks like its backwards. good eyes.
  12. PaulS
    good glasses! my eyes need quite a bit of adjustment at my age.
  13. 71_Maverick
    71_Maverick Member
    michigan
    opps haha at least its just a mock up. i believe the radiator is an all star. got it for $170 thought it was a good deal.
  14. matthewk92503
    matthewk92503 New Member
    77 Ford Maveric 30,000 Original MILES
    hey man were did u get the radiator form anad for a 1977 maverick and some fenders do u know were to get some???:Handshake
  15. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    rad
    will this rad keep a 351 W cool that is street driven?/
