2bbl carb on a 170cid
Discussion in 'Technical' started by Ron C, Feb 4, 2007.
  1. Ron C
    Ron C New Member
    Joplin, MO
    1970 Maverick 2 door, 170 I6
    I was wondering if there was any way of puting a 2bbl carb on a 1970 with a 170cid and a 1bbl carb? Any iformation would be helpfull! THANKS
  2. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    If it were my car I would put a better exhaust system on it 2 inch single exhaust a better muffler and a header if you can afford one. It would also be a good idea to do an ignition system upgrade too . The pertronix (sp?) system does away with the points and fits inside you`r stock distributor, you can get it for 80-85 bux . For a carb a webber 32/36 will still get you good gas milage and performance too you can get carb adaptors through these guys www.stoveboltengineco.com
  3. Halebopp
    Halebopp Member
    Ankeny Iowa
    does the petronix piece require anything else?, I've heard of a conversion that requires an ignition piece from the 78 fairmont. do they sell it for a 74 250, who sells it?
  4. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    ENGINEQUEST SHOWS CARB ADAPTER PART# CA200 WWW.ENGINEQUEST.COM SEE IF THAT IS WHAT YOU WANT
  5. mleega1
    mleega1 MAVERICK MARK
    Lagrange, GA
    1971 Maverick 2015 F150 2003 Explorer
    check out this site. I am currently putting a ford 2bbl carb on my 200, this site has all the info you will need http://fordsix.com/:thumbsup:
  6. elliot
    elliot Member
    Boubon MO
    No it don`t need any parts from other cars . I think you`r talking about the DSII ignition system ? I`m sure they make one fore you`r car, you should be able to get on at any parts store .
  7. Halebopp
    Halebopp Member
    Ankeny Iowa
    So the petronix piece is available at most car parts places, do I just tell them them motor size year etc and I want to do away with points.
  8. elliot
    elliot Member
    Boubon MO
    I was off on the price it was 80 bux for the ford v8s but its 112 bux for the I6s any way the part # is 1261 .
    Halebopp , Yup just tell them you wan`t a pertronix for a `74 ford inline six or tell them the part # .
  9. Halebopp
    Halebopp Member
    Ankeny Iowa
    It doesn't matter the type of distri butor I currently have does it, mine has a dual vacuum advance.
  10. Halebopp
    Halebopp Member
    Ankeny Iowa
    Thanks for the good info, I like getting one thing to make this switch!
  11. Halebopp
    Halebopp Member
    Ankeny Iowa
    I just located Pertronix web site, and did a search for dealers in my area it showed none in a 300 mile radius:hmmm: , do you know what parts stores carry these, becasue there is not, from what I see, a way to order direct form Pertronix:huh: ??
  12. Craig Selvey
    All the Mustang places sell it. Also: Auto Krafters.
    Also check ebay.
  13. Halebopp
    Halebopp Member
    Ankeny Iowa
    Yeah I see now they have a catalogue on line too, I 'll do more checking,
    I didn't look far enough into their website
  14. elliot
    elliot Member
    Boubon MO
    I think summit racing has them too ?
  15. Jamie Miles
    A 170 is such a weak engine to begin with. I really don't think I would even try to upgrade that engine. There are better options for the amount of money you would spend trying to get any decent amount of power out of that little 170. Even a stock 250 would be a huge increase in power.
