3.00 to 3.28 gears - worth it?
Discussion in 'Technical' started by facelessnumber, Aug 25, 2011.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    May have a chance at an 8" center section with 3.28 gears. My current diff is the 3.00 and I've been thinking 3.5ish would be an ideal ratio for my setup But this 3.28 diff is a pretty good deal. My question: Is this enough of a step up that I'd even notice? Should I even bother with it, or wait and get the 3.50 or 3.55 later?
    Also considering a Powertrax Lock-right or a mini spool, but I don't know, that's probably a whole other conversation...
  2. mercgt73
    mercgt73 Member
  3. rwbrooks50
    rwbrooks50 Member Supporting Member
    Forney Texas
    71 Maverick & 63 Ranchero
    IMHO. It is too expensive to change gears limited slip. Change them once. Ebay has a couple of builders that have pumpkins ready to install, you pick your gears.
    Rick
  4. rthomas771
    I see a big difference between a 3.00 and 3.25 with my 4-speed Falcon. With the 300 I had to ride the clutch too much to get rolling. A bigger cam likes bigger gears too
  5. seedeezy
    seedeezy Member
    Vancouver Wa
    1972 Comet
    If it was free I would do it. 3.25's are like an ideal street gear. The lock right is fine with an auto. If you have a stick, there is so much slack in them things you car will lurch on you at low speeds back and forth. Its not fun.
  6. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    I would go 3.55 or greater ... yields better readings on the fun meter (y)
  7. 71gold
    have that with 3:55 gears...auto, LOVE IT...:thumbs2:
  8. Joe Dirt
    I like my 3.27 gear fwiw I dropped from a 4.30 much nicer to drive now
  9. Red1972Grabber
    Northern California
    I also saw the pumpkins on ebay. If I remember correctly they were actually a decent price too.
  10. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    I would say go with the Powertrax lock-right 3.55
    friends camaro has similar setup, stock size tires. i want the setup in my next car
  11. facelessnumber
    Memphis, TN
    '71 Grabber
    Well thanks for the advice everybody. I still think my ideal setup would be the Powertrax and 3.55 gears, so I'll wait until funds allow... Unless I can talk the guy down a bit more on price, then I can run the slightly better gear ratio and keep the car in service while I build my original center section.
  12. Joe Dirt
    Too bad you don't have a 9" I've got the perfect center section for you =)
  13. facelessnumber
    Memphis, TN
    '71 Grabber
    If I do run across a 9" that fits, I will keep that in mind. (y)
  14. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Hey, I like that sig! Wonder where that came from? :rofl2:
  15. Mysidekickgoose
    Mysidekickgoose Member
    Knoxville, TN
    1974 ford maverick 4-speed automatic I6, 94' Toyota Celica FWD I4 5-speed manual, 84' Toyota Celica RWD 2.4L I4 5-speed manual
    hey got a question id like to throw out there since we're tlking about gears. if i go with a 351 small block, and a t5 manual, would a 4.10 be good or should i go with something else?
