3.55 or 3.80 gears
Discussion in 'Technical' started by JHodges, May 31, 2009.
what gears
  1. 3.55
    71.0%
  2. 3.80
    29.0%
  1. JHodges
    JHodges thumper
    Dora Alabama
    I will have my maverick ready pretty soon. I would like to get a better set or gears and a powertrax. My engine is an 86 roller stock cam with e6 heads, headers, performer rpm intake, 600 holley and 1.7 crane roller rockers. This will be a street car with some track time
  2. chirt
    chirt Carlos Hirt
    Massachusetts
    Man I have the same doubt but I'm leaning more to 3.55:tiphat:
  3. JHodges
    JHodges thumper
    Dora Alabama
    I'm thinking 3.55 too. I figure they should make a big difference over 2.79 and still be streetable
  4. 71gold
    i had pretty much the same setup w/AOD...3:55...
    :chirp:
  5. chirt
    chirt Carlos Hirt
    Massachusetts
    I got 3.00 and I think It's too high. I think 3.55 will give it a good start and still be nice at highway speeds
  6. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    If its going to be mostly a street car Id vote 3.55 any day over the 3.80s.
    I ran a 3.70 in a 390 F-100 and it was a bit to low for extended highway time (but I did it) and the interstate was definately out of the question
  7. mean_maverick
    if ur running a c4 or 4sp, go 3.55
    for aod's and 5sp's, id go 3.80 :yup:
  8. baddad457
    Ditto, except for using 3.80's with a manual trans mission 5sp. With 3.80's first gear will be completely unusable for anything but trailer towing. With the AOD, it won't be a problem.
  9. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    With a stock roller cam, I would think a 3.55 would be the way to go.
    HOWEVER, with the relatively high first gear of the c4, rear tire size could make the difference between which will work better for YOUR combo.
    Any tire with a rated diameter larger than 26" on your combo could use 3.80s without issues.
  10. JHodges
    JHodges thumper
    Dora Alabama
    I have 225/70/14 tires on my car. I'm not sure how tall they are
  11. ratio411
    ratio411 Member
    Pensacola
    Those are going to be 26" or less. Go with the 3.55s.
  12. baddad457
    Multiply 225 X .70 then multiply again by 2, then divide by 25.4. Add that to the rim diameter to get the tire diameter. If you want to know the rpms at 60 mph, take the tire diameter, multiply by Pi (3.1416) divide that into 63,360 (inches per mile) multiply the answer times the gear ratio to get rpms @60mph
  13. Bryant
    depends on what tranny and tire size your running. if you dont have a overdrive trans. then 3.55s may be to much gear. whats your intended use for the car?
  14. JHodges
    JHodges thumper
    Dora Alabama
    c4 tranny 26 inch tires, it will be a street car with some track time
  15. Bryant
    with 3.55s youll be doing at least 2900 rpm at 65. if you conveter is still sliping at that speed then your rpms will be higher. with the 3.80s you will be doing about 3200 rpm at 65. so that should give you an idea of what to expect for those gear ratios.
