3-speed to C4 conversion info needed.
Discussion in 'Transmissions' started by Ravishing11, Apr 18, 2008.
  1. Ravishing11
    Ravishing11 Member
    Pittsburg, Ca
    Maverick
    Hey guys, this isn't for my Mav, but for my g/f's mustang. She has a 66 with an I6 and a 3-speed manual. We're converting this to a C4 because she hates driving a stick. I'm doing the swap, but I'm not sure if I have the correct list of parts for the coversion.
    So far I have this:
    C4 tranny
    converter with ring gear
    flexplate for I6/C4
    kickdown cable
    tranny cooler
    shifter
    Does anybody know if I need to swap driveshaft, starter, or any other parts I may be missing???
    I know I should be on a mustang forum for this, but I trust everyone's knowledge on these message boards.
  2. Mavman72
    I believe the starter for an automatic is different from a stick starter(stick has shorter snout)Wont engage the ring gear properly and will grind.You need a starter for an auto trans.
  3. PaulS
    You will want metal lines for the cooler - rubber holds the heat too much and it is much more expensive than the steel lines. For the short connections to the auxillary cooler make sure that you get Parker "Push-lock" hose or equivelant. It will withstand 250 PSI and the high temps of the transmission. Fuel line will not hold the pressure for very long - leaving you with a bad core and the need for a new transmission.
    You will need a 1/4" metal line from the intake to the transmission's vacuum modulator. If you try to use a long rubber hose it will collapse under the vacuum and leave you with shifting problems.
  4. Earl Branham
    Lugoff, SC
    You'll need a pedal assy also.
  5. PaulS
    Can't the clutch pedal just be removed?
  6. Earl Branham
    Lugoff, SC
    Maybe. I went the other way (auto to manual), and used the entire pedal assy.
  7. Ravishing11
    Ravishing11 Member
    Pittsburg, Ca
    Maverick
    thanks everyone
  8. Ravishing11
    Ravishing11 Member
    Pittsburg, Ca
    Maverick
    Okay, I'm ready to install the tranny, but I'm not sure how many quarts of oil go in? I believe it's five or so, but I may be wrong. Also, how many of those quarts do I put in the converter?
  9. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I always put a couple of quarts in the converter before installing it. Make sure you seat the converter correctly or you will burn up the trans. The whole job should take about 10 quarts.
  10. Lassi4212
    Lassi4212 Young hotrodder
    Turku, Finland
    Comet -73, Capri -69
    How you can put converter wrong? I'm just asking because i just put my c4 back...:hmmm:
  11. Ravishing11
    Ravishing11 Member
    Pittsburg, Ca
    Maverick
    I just know you have to slide it down the input shaft properly so it seats. Wiggle and slide it forwad at the same time. If it doesn't go in properly, you would know because it would be pinned up against the flexplate and you wouldn't be able to get the convert bolts in and may have a problem bolting the bellhousing to the block.
  12. Lassi4212
    Turku, Finland
    Yes, we noticed that. We made that wrong couple times before it fit right.
  13. Earl Branham
    Lugoff, SC
    The converter will drop twice. Spin it in the trans till it clicks in, then spin it in one more time. When it clicks in the second time, it is seated.
  14. Ravishing11
    Ravishing11 Member
    Pittsburg, Ca
    Maverick
    Hey everyone, as I was trying to get the converter studs to line up with the holes on the flexplate and I noticed the center knob on the converter was not seating on the rear side of crankshaft. So I rolled the tranny back and noticed there was no opening for the "knob" of the converter to go. It appears to be a spacer of some sort--I'm not really sure. Any ideas on how to remove it. It's pressed in to the rear of the crankshaft. I installed the new flexplate and didn't even notice. Help please!!!
  15. Ravishing11
    Ravishing11 Member
    Pittsburg, Ca
    Maverick
    Here's a picture of it.
