351C and 351W
Discussion in 'General Maverick/Comet' started by 289, Jan 28, 2014.
  1. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    Need some help with telling my 351 block is a cleveland or windsor,
    the guy SAID it was a boss 351C but i am doubting. i could care less which one it is but i am going to sell the shortblock and i want to make sure which one it is.
    casting code- C90E-6015-A
    Can you tell if its a cleveland buy the casting code? all i can tell that its a 1969 351 out of a fairlane or torino.
    On top of the block though by the lifters it has 351 WF, which makes me think the "WF" means its a windsor.
    also has 2 bolt mains if that helps.
    thanks, nick.
  2. krelboyne
    krelboyne Remember
    Salem, Oregon
    I am not aware of any Cleveland engines with a C9... casting number. The earliest ones would be D0....
    Cleveland engines have the water neck in the block, because the intake manifolds have zero water passages.
    I think that you are correct with the "WF" Pretty sure it is "Windsor Foundry".
  3. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    :thumbs2: thanks just saved me from looking like an ass on cragslist
  4. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    Another question, what defines a "boss" engine? is it just the heads?
  5. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    And im guessing "boss" was just for the mustang?
  6. Krazy Comet
    If it looks like a wide 302 it's a Windsor...
    If it has the water outlet in the top of the block(not in intake), a cast on timing cover with vertical pattern fuel pump mount, it's a Cleveland...
  7. lm14
    lm14 Member
    Iowa
    The 351 Windsor has a bolt on aluminum timing cover that looks just like the one on a 302. In fact, a 351W looks just like a 289/302 but has a taller deck height.
    A 351 Cleveland has a flat steel plate that bolts to the front of the block and the timing cover area is cast as part of the block.
    351W has 6 valve cover bolts and a 351C has 8 valve cover bolts.
    Quickest way to tell.
    If it's a 351W it isn't a Boss of any kind.
    SPark
  8. Krazy Comet
    Boss was the name given to the Hi-Po Cleveland version used in 1971 Boss Stangs, most of the components are same as regular Cleveland engines...
  9. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    Thanks guys.
  10. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    The Boss 351 had adjustable valve train, a solid lifter cam, an aluminum dual plane intake, different keepers on the valves, pushrod guide plates, a 4 bolt main block and domed forged pistons as the major differences. It was essentially a beefed up and modified Cleveland 4V engine.
  11. rthomas771
    Fuel pump bolt holes are also different
  12. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Now, which is the best to build? Most power/torque, and which is the strongest for abuse?
  13. krelboyne
    krelboyne Remember
    Salem, Oregon
    Cleveland's were used 1970-74, not much high performance support in the last 20 years, and expensive to build.
    351W is the way to go.
  14. Krazy Comet
    Comparing the best vintage 351W(1969, 290Hp) & 351C(1970, 300Hp) it ain't even close, the C will take names and kick butt big time... BUT as mentioned, Cleveland evolution basically ceased in the '70s/early '80s...
    There were 351M(modified) built from '75-'80 that were basically Clevelands in the taller 400 block(almost as large as a 460) but those weren't really high perf engines... Still with a good set of earlier 351C heads on a M or 400, along with cam, intake & headers they could really rock and are still somewhat popular with the early truck guys...
  15. junrai
    junrai Member
    rancho cordova ca
    my dads truck has the 351 m I keep telling him to scrap the truck and pull the motor even though its not a power house it has never let him down. in 10 years all hes had to do to it is put in a timing chain and rebuild the carb. the problem with these motors is they were smoggers so not meant for alot of power
