351W 302 question
Discussion in 'Technical' started by EFIMAV, Feb 17, 2011.
  1. EFIMAV
    EFIMAV Member
    Davenport Iowa
    I know the 351W is wider and taller, but not longer. It uses a different oil pan, intake and distributor. But, I can't recall if it requires a different timing cover and gear set. I know the cams can be swapped. Thanks.
  2. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    Same thing they swap right over.
  3. EFIMAV
    EFIMAV Member
    Davenport Iowa
    Thanks for the response
  4. baddad457
    :thumbs2: Ditto.
