351W/4speed swap
Discussion in 'Technical' started by coutangman, Sep 10, 2009.
  1. coutangman
    coutangman Member
    Charlotte, NC
    I am considering swapping a 351W out of a '69 Cougar and a toploader out of a '72 Mustang into my '72 Comet GT. I also have a toploader 3+OD which I can use. Which toploader would be better and what problems trying to install a 351/4spd in a GT would be?
    Jim
  2. Joe Dirt
    the 3+ is a little weaker trans then a real toploader
  3. maverick maniac
    maverick maniac Banned
    owensboro ky
    the 3+1 is only weak in the 4th gear the rest is a good trans to run windsors are tight but do fit I am putting one in my car right now
  4. maverick maniac
    owensboro ky
    you will also need z/bar stuff
  5. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    Same here....just got my install 2 days ago ....the factory granada shifter is a little sloppy but you can always spend 4 times the cost of the tranny you can get an adapter and hurst shifter.:cry:
    Robert
  6. coutangman
    coutangman Member
    Charlotte, NC
    What I am mainly concerned with is using the toploader with the 351 instead of an automatic. I think I read that you could not do it because of steering column obstruction to the exhaust or clutch z bar problems or something else in that area.
    I have both factory linkages and shifters for the 2 transmissions. I also have the larger bellhousing, clutch pedals, z bar, mounting ball, etc for the swap. I will need a few other things, but my main concern was to actually even be able to do it.
    On a side note, the rear end currently in the car has 4:62 gears with a mini spool. I also recently bought another complete rear end with 3:00 gears. I will probably use the 3:00 rear and sell the other one. Anybody know what 4:62 rears are worth?
    Jim
    Jim
  7. baddad457
    4.62 gears plus the OD Toploader's first gear equals stump pulling power.
  8. paxtond
    paxtond Member
    Ontario
    1971, 1976 Comets
    I am doing the same swap into a '71 Comet. Problem is I don't have the rest of the car ready yet. I have the parts but haven't done the test fit yet. From what I have read it's doable but the problem is with the headers and the Z-bar stuff. Obviously the 351 will fit based on what's already been posted on the site, and the bigger bell will fit based on what's been posted (I believe MercGT73's posts (http://www.mmb.maverick.to/showthread.php?t=58349) show a big bell and Toploader combo he pulled out. What I haven't seen is any posts with the 351W/Toploader and headers. I think the headers are the major hurdle for the linkage.
