351w engine swap
Discussion in 'Technical' started by runeking40, May 18, 2010.
  1. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    at first i was thinking about putting a 302 in my 1973 ford maverick 250 inline 6 and i was wondering what is the difference between the 302 swap guide and the 351w swap would i still buy 302 motor mounts and can i still use the radiator and c4 bell housing on the 351w. The only thing i thought you had to get different was headers and im not to keen on cutting the shock towers i have no problem jacking the engine up for spark plugs.
  2. maverick75
    Then don't cut the shock towers, they don't give you header clearance.
    Unless your building a drag car i would go 302, they can make all the power you would ever want.
  3. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    but would the 351w need a different c4 bell housing or different motor mounts or different radiator
  4. Dave B
    http://en.wikipedia.org/wiki/Ford_Windsor_engine
    Although related in general configuration to the 289-302 and sharing the same bell housing, motor mounts and other small parts, the 351W had a unique, tall deck block, larger main bearing caps, thicker, longer connecting rods, and a distinct firing order (1-3-7-2-6-5-4-8 vs. 1-5-4-2-6-3-7-8),
  5. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    thx man would the headers for the 302 fit and clear everything on the maverick on the 351w
  6. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    the clearance on the 351w will not work like the302 will. me and my son found this out on his 1964 fairlane the wider deck limits the clearance for the headers or the. manifolds
  7. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    so where can i get heads for a 351w to put on my maverick on a tight budget because i found 302 headers for 150$
  8. Dave B
  9. metalnate
    metalnate Member
    Sioux City, Iowa
    1972 Maverick Grabber
    if you dont want to cut the shock towers you might have a hard time getting headers on the 351. my maverick has a 351 windsor in it, and with the exhaust manifolds it is a VERY tight fit.
  10. troberts289
    troberts289 Member
    Lynden Washington
    1972 Ford Maverick
    302 headers wont fit the 351 in a maverick. the 351 sits taller in the engine bay on account of the raides deck height. so the 302 headers wont drop down far enough. you can always doas mustang II front suspension modification to just lose the shock towers all together. then you can run whatever header you want. But thats pretts spendy. my advice is stickl with the 302. They can make plenty of power.. As for the bellhousing question. Yea a 6 bolt C4 will bolt up to a 351 block.
  11. CaptainComet
    The biggest issue is that the 351W is 1.5 inches wider than the 302 at the exhaust ports. The header pipes and the upper A-arm bolts want to be in the same place. Oil filter gets close to the shock tower, too. On top of that, you can barely get the carb under the hood. Forget about getting a decent manifold with a bit of height to it without tucking the air cleaner under a scoop. A 302 fits really well and a 351W almost doesn't fit.
    Like Dave said, if you are on a budget, go with a 302-based motor. 351 headers are a very big added expense. These cars are almost featherweights and it is so much easier to build a strong 302 now.
    The next time I pull my 351 out of my Comet, if it needs more than just rings and bearings, I will probably be going 331 stroker next.
    Even with a 302 motor, I would still cut the shock towers back. :thumbs2: It really makes it much easier to do plugs and header bolts. I used to go through two beers changing the plugs in my stock 302, and I don't quite finish one when changing plugs in the 351 with the cut shock towers. Usually no cussing or bloody knuckles, any more, either.
    The three scales on which I rate the difficulty of automotive work ... :dancing:
