351w question
Discussion in 'Parts Interchange' started by bartikus, Feb 28, 2006.
  1. bartikus
    bartikus Member
    salt lake city, ut
    will the stock exhaust manifolds, on a stock 351w, fit in my engine compartment or do i have to use the 302 manifolds. i would really like to use the 351w manifolds because they are bigger and should have better flow.
  2. don graham
    if i remember right, my experience is that if you use the 302 manifolds on the 351 they will stick out to far. i believe the 351 manifolds are closer to the block. someone can correct me if i'm wrong again.:)
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I don't know. Same head dimensions, I would have guessed that they are the
    same for both.
    Seth
  4. don graham
    the difference is not the heads but the rest of the block. the 351w is a wider block than the 302.:)
