393w i built for maverick
Discussion in 'Drag Racing' started by maverickmadness, Jul 9, 2013.
  1. maverickmadness
    maverickmadness Member
    ala
    1973 maverick grabber, 1972 maverick grabber,1974 maverick grabber,
    393 w, brodix heads ,probe pistons, h beam rods, custom flat tappet cam. anyone know how I can post vid of motor on the breakin stand , it sounds very healthy:drive:
  2. Bryant
    you can post a link to videos on youtube.com that we can click on.
  3. maverickmadness
    ala
    the sound isn't as good on youtube but it is what it is
    goldglow73 likes this.
  4. maverickmadness
    ala
  5. JHodges
    JHodges thumper
    Dora Alabama
    I look forward to seeing what it will do at the track
  6. Moneymaker 1
    Panama City Florida
    Hey I have a 1972 Grabber that's ready for that engine! I can come and pick it up any time :rofl2:
    It sounds great! be sure and let us see a video of you turning it loose ASAP!
  7. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Should be pretty stout,good traction bars,slicks,beefed up trans and rear w/ low gears it`s a 10sec 1/4 mi car easy.I`ve decided to go 393 also with my build,I believe w/ 6.2 rods and 1.325 comp. height pistons it will live longer than a 408,and very small diff. in power.Don`t rev the mtr. over 7000 rpm and it will live a long time,good luck at the track.:yup:
  8. maverickmadness
    ala
    we are too but still got some more work on the mav to do.
  9. SOHC MAV
    SOHC MAV Member
    Iowa
    72 Maverick, 93 F-150 Lighting,71 Pinto,67 440 Dodge Dart
    Yep!
    That thing sounds BAD! Any idea what kind of horse to expect from it?
  10. maverickmadness
    ala
    thank you dan . hope your build goes well also. don't know what ours will run, as the set up on car is as important as the motor, but we have a pretty good feeling on this also,
  11. maverickmadness
    ala
    thanks sohc. no idea as it hasn't been on a dyno. but it has some good parts and should be healthy. it will be a while before we finish car but are working to that end. thanks to all for their comments
    :chirp:
