4 cars ahead of you
Discussion in 'Drag Racing' started by tank, May 18, 2010.
  1. tank
    tank New Member
    Texas
    comet
    iam expecting arouind 2400 coming my way but i need help making my comet faster. right now the top speed is around 105. the gears are slow at changing. I also have an arch enemy lol its just a car that i see all the time when i get off work its a pontiac grand prix gtp. He just pisses me off the first time i had him but my car changed gears slow so he took me. But i just want some hints on waht i can work on to get the speed and gearing up. http://www.facebook.com/home.php?#!/photo.php?pid=85302&id=117873608252324
  2. maverick75
    take off that front bumper to reduce weight lol
    what are the specs on the car?
    when you mention that the gears are slow to change im assuming you have an automatic? do you shift gears manually or leave it in drive?
  3. tank
    tank New Member
    Texas
    comet
    yhea its an automatic its a c4 evrything is pretty much as how it was when it was built in 1973
    c4 transmission automatic
    302 2 barrel carb
    drum brakes
    dump exahust
  4. Mavman72
    Put a taller gear in the diff....Go to 3:55s' that poncho wont know what hit em.Just remember,that poncho is supercharged so he has a bit more on top than you.Shift it manually as well...
  5. tank
    tank New Member
    Texas
    comet
    i was thinking about a floor shifter maybe to install my friends says he know how to install them but idk if i should go with that
  6. don graham
    A floor shift is not going to make any difference if the tranny is slow shifting. A cam, 4 barrel carb and manifold, headers, ignition, rear gears and tranny rebuild are the start. Remember you are going to lose gas mileage, if that matters. These are by no means the only thing that needs to be done. It is a snowball effect. Remember the faster you go the need for better braking comes up to.:)
  7. justin has a 74
    kentucky
    Thats a nice car, leave it big bumper and do what don said!
  8. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Follow Don's recommendations...I would have said the same exact stuff.
  9. Craig Selvey
    Since we are talking street racing, I would suggest getting a really good lawyer for when you get busted.
  10. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    If it aint that guy,,, it`s gonna be another! Craig has a excellent point!
  11. tank
    tank New Member
    Texas
    comet
    wow wow hey craig i never said street racing. i was going to flag the gentle man down and i was going to invite him to the track.:thumbs2:
  12. olerodder
    olerodder Member
    NorCal
    The first thing I would do is to put a performance shift servo in the C4. This will help with the sloppy shifting between 1/2 and 2/3. It is easy to install and can be had for around $100. Performance Automatic also builds performance kits for the C4 and new transmissions. I have used them since they started in business and they are one of the best with a great tech department.
    Then, I would put a set of headers and X pipe, and change the rear gears to at least 3:55's. Unless the motor is in really good condition I would do just these mod's and see where you are. If the motor is in really good condition then go ahead and put a street cam and add the intake and small 4brl carb.
    Take it from someone who drives a "drum brake" race car in the 10's at over 130mph...........................You Want To Change Those Drums Over To Disc's ASAP!!!!!!............unless you have a 12' diameter parachute!
    IMHO
  13. olerodder
    olerodder Member
    NorCal
    It's late and my fingers are going faster than my brain................here is the website...........http://www.performanceautomatic.com/parts_c4.htm
    for the shift servo.......................it works without tearing the complete trans apart.
    IMHO
  14. maverick75
    I just noticed that its not a big bumper, its a 73 , at first i thought it was :hide:
  15. justin has a 74
    kentucky
    Half big?:Handshake
