4 lug to 5 lug convert cheap
Discussion in 'Technical' started by Banta, Mar 11, 2015.
  1. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
  2. Bryant
    that looks like it will only bolt on to 3 of the 4 lugs. seems like a step backwards.
  3. Craig Selvey
    I think it would be easier and safer to:
    Find a set of 4-lug wheels.
    Convert the car to 5-lugs.
    I would pass on those.
  4. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Look em up on ebay. It shares 1 hole with the factory lug. And it comes with a long stud to go through both plates. It will still be mounted down with all 4 lugs
  5. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
  6. biggruss
    biggruss Member
    picayune,ms.
    1970 maverick grabber,1975 maverick (parts car)
    you're still gonna have drum brakes?? why not convert to 5 lug disc brakes?
  7. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Figure I'd give em a whirl. Cheap enough. And I'll put em on when I get some 15 5 lugs. Then later on when I find all the parts I might go to disks and pass the spacers on to the next comet fan
  8. Shorty
    Shorty Member
    Lafayette, In
    I used wheel adapters on my first Maverick for a couple of years until I upgraded to five lug hubs. Had to have cool wheels/tires! Install them properly making sure they're torqued correctly, check them frequently and you should be fine.
    Bruce
    Banta likes this.
  9. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    I just mainly want to see if I like the 15 inch rims on it and how everything sits and rides before I dish out all the time and effort to convert it just to not like it. To me this seemed to be the easiest cost efficient way to go 5 lug.
  10. 71gold
    I thought you were looking to go to...4 lug disc...:huh:
  11. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Disk for the front.
  12. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    I seen the adapters online and thought that it be quick to do while I look for a disk convert for the front and most I'm seeing is 5 lug. And I want to be able to rotate my tires in the future
  13. Bryant
    installing that long stud in the rear axles will be fun. most likely the axles will have to be pulled. still less work that swapping the whole rear end. then if you get 15" wheels the back spacing will be for with the spacers. if you get rid of them and do a 5 lug conversion the wheels will have the wrong back spacing.
  14. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    I figured as much. But it's no big deal for me
  15. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Why not look at wheels from a Fox body Mustang, plenty of options there for four lug. You might even get a decent looking set for the price of the adapters.
