4 to 5 lug question
Discussion in 'Technical' started by Dilloz, Jun 5, 2014.
  1. Dilloz
    Dilloz Member
    Ohio
    1972 maverick 2 door 302 / 1972 maverick 4 door w/ a 302
    I have a 72 4 door v8 donor car with 5 lug axels, I want to swap the 5 lug parts to my 4 lug 72 2 door. Do I have to swap everything or just the brakes/backing plate. Also, does the v8 and 6 cyl cars have the same spline? Thanks
  2. Acornridgeman
    Wisconsin
    You will need to swap the entire rear as a unit - the axles do not swap between housing because the bearings are a different size. All Maverick 8" are 28 spline.
    Since you are not keeping the car original, I highly recommend swapping out the front for disc brakes. All the "Granada disc swap" items are sold new, as a kit now. No need to hunt junkyards for donor cars.
    Search the forum - there are 100's of threads on these swaps.
    :burnout:
  3. Dilloz
    Dilloz Member
    Ohio
    Thanks for the info!!
  4. captainmack
    captainmack Quad Door
