4000RPM on the freeway...
Discussion in 'Technical' started by mashori, Oct 5, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    First time I have a tach in this car that I commute with and at 70mph I'm almost 4K RPM on the freeway. I usually go 75 and I'm almost 4200 at that speed. Have a stock 302 with I'm pretty sure is a stock rear end with a stock C4. Car doesn't have any major problems I'm aware of. Only thing it's always done it shifts hard into 2nd gear and kinda winds up hard before going into 2nd.
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Ummmm...no, of course not!
    Ok maybe...
  3. justin has a 74
    kentucky
    yeh 4 grand doesnt sound right... you trying to floor it lol
    my car did 2000 stock and now does 2500-2700 with cam high rise intake AND 4 barrel carb at 70
  4. rthomas771
    The rpm seems right with the mph if you have a 3.25 gear ratio with small diameter tires.
  5. justin has a 74
    kentucky
    still seems a bit high:rolleyes:
    go check that axle number on it
  6. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Mine was around 3500 for 60mph. Not exactly built for speed were they?
  7. Bryant
    the tach must be set for 4 cyl.
  8. gulupo
    gulupo Member
    nuevo laredo,Monterrey mexico, Laredo Tx
    1970 ford maverick
    the problem is the 3 speeds transmissions, thats the problem. you need and AOD or a 5 speed.
  9. PAINTANK
    1973 Comet 2 dr
    Tach is set for 8cyl. Idles at 900-1000, shoots to 4000 at 60+mph.
  10. PaulS
    You don't have stock gearing /...........
  11. Acornridgeman
    Wisconsin
    I just ran the calculations
    70 mph
    1:1 transmission ratio
    3.00:1 rear end ratio
    26" tall tire
    = 2713 RPM
    :tiphat:
  12. Jamie Miles
    These modifications will not affect the RPM... unless you transmission is slipping now from the extra power.
    I haven't driven my Maverick in about a month and a half, but it seems like it always stayed around 3,000 at 75 mph.. That's with a 2.79 gear.
  13. justin has a 74
    kentucky
    huh... ide think that cam would do something to the compression??? or mabey thats something else:rolleyes::huh:
  14. PAINTANK
    1973 Comet 2 dr
    I can guarantee my car is bone stock and the rpms are too high for my taste when cruising the highway. My F150 is 3000rpm at 55mph.
    I have no idea how to measure or determine the gearing. VIN could help? ID tag?
  15. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Put a jack stand under one side of the axle so one wheel is off the ground, one wheel on. Put the transmission in neutral. Crawl under the car and put a chalk mark on the driveshaft. Have a buddy turn the raised wheel exactly one revolution while you count the drive shaft revolutions. Divide the count by two and you have the rear end ratio.
