400m maverick
Discussion in 'New Members Forum' started by 69fordmaverick, Jul 23, 2008.
  1. 69fordmaverick
    69fordmaverick New Member
    FREDERICK MARYLAND
    19691/2 FORD MAVERICK
    When I was 18 I had a my first Ford Maverick which was a 1970 with a 302 automatic small cam headers four barrel intake a carb, with grabber hood. I sold it two years later, I regreted it. The person that bought it totaled it 2 days later. I have searched for another Maverick to fix up and build and I finally found one. It is a 69 1/2 Maverick with only 57,000 miles everything is original no tears or body damage no rust very amaculant. It has a 200 6cyl. I am putting a 400m with 292duration 536 lift,double roller timing chain, dual point distr,750 holley double pumper, 3000 stall converter with shift kit and blow bell housing, with 8 1/2 in ford rear 456 gears. It will be done in 2 weeks. Cant wait!!!!!!
  2. newtoford
    newtoford Member
    New Castle Delaware
    welcome abord
    good luck with the swap. did you have to do alot of cutting to get that motor in?
    im not sure im famiular with a 8 1/2 in rear? just the 8'' and 8.8''?
  3. 69fordmaverick
    FREDERICK MARYLAND
    It is a 8.8 rear out of a comet. I will drop the motor in within the next 2 weeks we measured and the valve covers are 4 inches over shock towers carb will be out of the hood. I am just laying the motor in and welding steel plates for mounts. I will let you know how it goes.. I was going to do a 302 but everyone around here has 5.0 mustangs with 302's and I wanted something different. My motor is a 6.6 liter.
  4. don graham
    What year comet did the 8.8 come out of. Hope that motor is not too heavy. Are you doing any suspension mods? you know, there's a reason there's not too many 400ms in Mavericks. 351w can be stroked to a 408 or more and a lot less headaches. Hope it works out for you. BTW welcome to the board.:)
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    :ttiwwp:
    If it will be done in 2 weeks, you must have most of it in hand and worked out.
    Come back when you got pics!
    Btw... Welcome back to the Maverick family!
  6. rayzorsharp
    Welcome aboard! :Handshake
  7. chirt
    chirt Carlos Hirt
    Massachusetts
    :Welcome:I can't wait to see these pictures!!:clap:
  8. Pasc
    Quebec, Qc
    76 Stallion
  9. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
  10. 69fordmaverick
    FREDERICK MARYLAND
    i have a c6 transmission but im using my c4 so its not so big and it will fit in alot easier.
  11. ratio411
    ratio411 Member
    Pensacola
    I'd like to see pics of that.
    My 351c had about that much clearance, but is a narrower engine.
    Doesn't quite add up.
  12. mav1970
    I was thinking the very same thing. I had a lot of knuckle bleeds messing with spark plugs near those towers. Also my hood shut with no problem with the Cleveland. How much taller is an "M" engine anyway?
  13. 69fordmaverick
    FREDERICK MARYLAND
    The size of my 400m from valve cover to valve cover is 26"wide the motor is 24" tall from ground to the stock valve covers and the other valve covers i am using is a 1" or 2 taller. from the ground to my carb it is 32". on my 69.5 mav from shock tower to shock tower it is 24". I know the spark plugs are going to be a pain in the but hopefully i can burn holes in shock towers enough to get the socket thru. I am going to order shorty truck headers hopefully they will work. I am waiting on my bellhousing and stalk converter to finish the car. if anyone needs a c6 I have one that came out of a 79 lincoln. i know i can fit the 400m in mine my buddy has a 460 in his.
  14. ratio411
    ratio411 Member
    Pensacola
    Not with stock towers.
  15. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    That's what I'm a thinkin'. Unless the engine is going to sit up out of the hood like a Zinger.....
