??????427??????
Discussion in 'General Maverick/Comet' started by New2Maverick, Jan 25, 2004.
  1. New2Maverick
    New2Maverick The Newbie Sponge
    Oregon
    1974 Maverick 4 dr, v8 302
    What is the popular opnion on the Ford 427? I have a friend here telling me that I should figure out how to shoe horn one of those under the hood of my 74 mav.
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    old school cool. Great motor my father loves the 427. Today however you would be better off going with a stroker 347 or 331 based on a 302 block. Bolts right up and you will perform great. The other way you could go is 351 stroker 393ci 408ci 427ci 454ci, with the aftermarket available heads for small block fords You should have no problem building a powerhouse that exceeds an old 427 with half the weight. Good Luck.
  3. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    I agree with 1badmav. On the one hand a 427 would be cool to see, but on the other they are a heavy motor and don't have very much aftermarket support. If you went with a 302 or 351-based stroker motor you could have the cubic inches without the weight, not to mention the cost.
  4. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    They are Expensive....
    ...and rare. I agree, build a small block motor.
    I have a friend with a 427 high riser in a
    '69 Mach I. It probably puts out 600 HP
    and costs about $12K to build (motor).
  5. rayzorsharp
    Not to mention it won't fit your engine compartment. You would have to do some serious modifications. :(
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I agree, stroke a small block!
    I have pulled away from many a big block with big tires with my little 302!
    Quote:
    "you must be fast, cause I was hauling ass when I went by you!"
    :D
  7. BIGbully
    BIGbully Maverick Maniac
    Omaha, Ne
    Yep. Even if you could put an FE series big block in a mav, my bet is the handling characteristics would be downright dangerous with that kind of weight up front. Gotta have Cubes? Go for 351 based engine. My old 351C mav shocked many a BB Chebbie. Use the advantage of our lightweight cars.
  8. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    You know, there are several companies that make the 427 stroker kit for the 351W!! All the cubes without the weight!!!
  9. mavman427
    mavman427 has entered the building.
    SLOtown, CA
    1971 Mav with all the trimmings....302 Auto, Custom buckets, Power Brakes, A/C, PS, Grabber hood, spoiler, and mirrors.
    Well, I love 427's. Look at my name, I even have it in there :). 427's are legendary. It's basically the Ford version of a Hemi. Bad ass engine for the time. With that being said, you can get as much or better performance for less $$$ with a modern engine. 347 strokers pump out 500+ horses at the flywheel with the right combination of stuff on it. And chances are, unless you're running slicks, you won't even be able to put all that to the pavement anyways. Just my .02.
  10. New2Maverick
    Oregon
    THANKS
    Well guys that is the kind of response I was looking for. Thanks for all the input opnions.
    :D :D :D :D :D :D :D :D
  11. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    427 was a great motor, but 428s worked better on the street. The original Ford stroker trick was to put a 428 rotating assembly into a 427 block, making 454 cubes.
    I am not a fam of small block strokers over the 392 Ford puts out. Too much side loading means you will be rebuilding every 50k.
  12. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    Yeah, i wanted to put in my .02 on the 351-based 427...not reliable at all for the street. Best to stick with 392 or less.
  13. New2Maverick
    Oregon
    Well the car came with a 302 in it when I traded my Bro cars. The entire car had been pretty well neglected. I mean the plug wires were held to the plugs with electric tape for cripes sake!!!:eek:
    So my main goal is to just get the current motor back up to par then start on the interior. After that who knows? More than likely I will start making the 302 that is in there beefy.:D
  14. CornedBeef4.6L
    no longer here
    I would agree on the 427 351 w stroker but a 408ci is just fine as well I went with that instead of 393 or 392ci. Talked to some local guys and they have been over 80,000 miles no problems. Past that there seems to be a general consensous there is too much side load.
  15. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I also agree with that theory if your building a street car.
    331 instead of the 347.
    But if it is race only....more more more cubes!
