4dr rear leaf springs on 2dr
Discussion in 'Technical' started by maverick7072, Oct 19, 2013.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    are the leaf springs different on the 4dr what I mean is is there a extra leaf cause I woul dlike replace mine on the 70 to maybe raise it up a little more.im going next weekend to check on a few parts cars a guy has thought I might do the spring swap he has a couple of early 4 drs and one 75 4dr
  2. bigdan56
    bigdan56 Member
    Spokane Washington
    04 F150, 2009 suzuki Boulavard m90, 77 maverick
    I used a pair of springs from a 71 4 door from a wrecking yard on my 77 2door after I had them rearched and a leaf added to give my 4. I haven't driven enough to get them to settle yet but I ended up with a 3" raise in the back. (was really to much):rolleyes: now shocks are short!
  3. rthomas771
    You cant go by the number of leafs to know the spring rate. Some 3-leaf springs were stiffer than some 4-leaf springs. You also need take note the bushings also change through the years
  4. tody
    tody Member
    cologne, germany
  5. Mercurycruizers
    Venetia, PA
    I put a set of leaf springs from a 74 Comet 4dr, on my 70 Grabber. I also swapped the 5 lug rearend from the same car. Now the 70 Grabber has a slight rake to it. I think it looks good. I'll be putting the front 5 lug manual disc brakes on next, from the same car.
  6. Dave B
    But since you can't buy replacement springs from Ford these days, and most junk yard springs are over 35 years old, I doubt knowing spring rates, will be of much help.
