5.0 swap question
Discussion in 'New Members Forum' started by cometguy75, May 19, 2016.
  1. cometguy75
    cometguy75 Member
    maine
    1975 mercury comet
    Hello quick question. I am doing an engine swap in my 75 comet. I have a 5.0 from a 89 crown vic. I know I will have to swap the oil pan did some research here and many say get a front sump oil pan. Not a lot of old cars in junk yard up here to take one from do you have a specific year an model for front sump pan and oil pickup? I will buy a new one off Rock Auto or something. Thanks great site.
  2. Krazy Comet
    If you are going carb, wimpy as it may be that engine will have a roller cam and require a steel or other custom dist gear...
    Any 289/302 vehicle before 1979 should have a front sump pan...
  3. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Welcome to the Forum!!!
  4. Hotrock
    Munroe Falls, Ohio
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  6. 70GreenMonster
    70GreenMonster Member
    Space Coast, Florida
    Welcome to the forum.
    This is an inexpensive one that will fit: http://www.summitracing.com/parts/sum-g3534/overview/make/ford
    I got one that was chrome and part of a kit to do just what we are doing, put a modern motor in an old car.
    it came with everything that needed to be swapped: http://www.jegs.com/i/JEGS-Performance-Products/555/50300K/10002/-1?parentProductId=757661
    these are before and after shots of my 99 explorer motor and what it looks like installed:
    for my setup, I wanted serpentine, not V-belts, so I used the complete setup from a junkyard 94 F150.
    I haven't got my A/C compressor yet, so this is a shorter, temporary belt, here it is in the car: 100_2653.JPG
    you will also need V8 motor mounts and frame stands.
    Good luck with your build!
    Maverick Dude likes this.
  7. Paul Masson
    1971 Grabber
    :Welcome: to the Forum from just across the border in New Brunswick!
