5 lug swap
Discussion in 'Technical' started by FoMoCo73, Jun 13, 2004.
  1. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    '73 302 parts car 1969 1/2 351w/tko-500 in progress
    hey, ive got a 4 lug 69.5 and a 73 5 lug mav. i want to change the 69.5 to 5 lug.in the front, can i just switch the drums over...with the original 69.5 spindles?
    in the rear i think im just going to change out rearends...
    also...what kind of rear end is in that 69.5? it looks nothing like the 8 inch. like a 7.5 or something?
    Brent
  2. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    brakes
    One way to find out. Go to a parts store and check the spindle part numbers for the two. If not that, check the bearing part numbers to see if they're the same. Almost bet thou that the 5 lug, V-8s are bigger then the 6 cyl 4 lug ones. Never know until you check.
  3. LightBlue70Mav
    LightBlue70Mav Member
    yadkinville, NC
    1970 Maverick, 1972 Maverick Grabber
    well, i aint no expert at 69.5 rears, but i've heard that those were german rearends, and they are Very weak. the way to identify these is that the german axle was a salisbury type (it has a sheet metal cover in the back) rear.
  4. Earl Branham
    Lugoff, SC
    All the 69.5 cars were six cylinder cars, and had the 7.5" rear. Get the 8" in there, it is much stronger. On the front, don't know if the spindles will work. Might try to get a set of Granada disc or Mav/Comet disc, and swap them over. Easy to do, much safer.
  5. bmcdaniel
    All Maverick drum brake spindles are the same part number.
